What am I doing wrong here? Trying to get a message when the garage door has been open for 1 hour. I got 35 messages. I only want 1.
HS3 Pushover Plugin
Originally posted by Radhoo View PostWhat am I doing wrong here? Trying to get a message when the garage door has been open for 1 hour. I got 35 messages. I only want 1.
- 3 likes
Originally posted by mrhappy View Post
It is something I have already thought about but not something I realistically wish to do, I don't really like the thought of someone potentially profiting from my work (there would be nothing I could do to stop them) and it would take me some time to comment everything to a point where someone else could actually understand it. The plugin is not overly complex and someone wishing to make a Pushover plugin for HS4 would be just as well to start from scratch.
- 1 like
Originally posted by bsobel View Post
You realize you can control that based on the license you publish it under, right?
- 1 like
- 2 likes
Hi.
sorry to bring this up again but for some reason 90% of my pushes wont go through.
i get this error on almost every push i send. this one was when i tried to attach a 300k picture.
any idea what i should do next?
thanks
Oct-04 09:31:18 Pushover 3P Error POST URL Data at the root level is invalid. Line 1, position 1.
thanks
If you can try that version and let me know then I will be able to advise further.
I'm sorry I did reply in post #1131 but as I didn't do a direct quote you probably did not get a notification.
sorry but that didnt help at all.
since i had a lot of slow responses on my linux machine, i moved my HS3 back to windows and all is well again.
i think it is a linux compatibility issue
hi.
Originally posted by mattstevenson2005 View PostHi, the documentation link seems to be still down.
Does anyone have the list of instructions on how to get the plugin to function?
Matt
bsobel I have just submitted v.47 to the updater which has some of the requested changes in it, just waiting on approval.
- 1 like
Just installed and trying to register a new app and get error. "Application FAILED to validate with Pushover..."
I have copy and pasted. Even created a new app just to test. I am on .47
The event logs show.Oct-09 3:42:26 PM Pushover 3P Application Verification Failed ThanksOct-09 3:42:26 PM Pushover 3P WebException Error: The remote server returned an error: (400) Bad Request.
Mike
Originally posted by themlruts View PostJust installed and trying to register a new app and get error. "Application FAILED to validate with Pushover..."
Mike
1) Stop the plugin
2) Open your HS3PushoverConf.ini file which is in your \Config directory
3) If you don't have an [APITokens] section then add this to the bottom of the file
4) Then enter a key like this appname=appkey and save the file
5) Restart the plugin, see if the application name is now in the event actions
It should look something like this;
Code:[Settings] UsrKey=KWnsGKueetY17to66uAypaJn6xxxxx eInterval=60 eExpiry=200 WantDevices=False FloodNumber=50 [Clients] iPad=removed nexus7=removed iPhone=removed redminote4=removed cttiphone=removed honor9lite=Nothing [APITokens] HomeSeer=cJvZXLNqBGifwKv2AcqfR5namxxxxx default=cJvZXLNqBGifwKv2AcqfR5namxxxxx
I have a curious thing happening when I get a high-priority notification. If I remember correctly, High priority would keep notifying me until I "acked" it from the receiving device.
Now it appears that it occurs automatically...
Oct-13 9:46:19 AM Pushover 3P Pushover Notification Sent - Message Title HomeSeer Log Errors This is occurring with an iPhone running the newest OS. As it happens, I also upgraded to the newest version of the plug-in about the same time.Oct-13 9:46:19 AM Pushover 3P Reply: 1 780f1f39-fef0-49cf-87a8-5fdf164bf0fb
Ideas?
Originally posted by Monk View PostI have a curious thing happening when I get a high-priority notification. If I remember correctly, High priority would keep notifying me until I "acked" it from the receiving device.
Ideas?
