OK - my faulty memory then - thanks guys.
HS3 Pushover Plugin
HS3 running on a Pi Linux Version (Standard Lic)
Plug in looks like it starts fine.. Enabled but when I click configuration in plugins for Pushover3p >>> Error?
here is what it looks like on terminal side
07:11:02:4399:[Starting Plug-In]->Pushover 3P loaded in 15076 milliseconds
07:11:02:4635:[Plug-In]->Finished initializing plug-in Pushover 3P
07:11:03:8551:[Info]->Plugin Pushover 3P has connected. IP:127.0.0.1:37174
07:11:03:8852:[Starting Plug-In]->Initializing plugin Pushover 3P ...
Connected, waiting to be initialized...
[2019-10-25 7:11:04 AM] Plugin Starting - Checking if HS4/HS3...
07:11:04:2955:[Pushover 3P]->Plugin Starting - Checking if HS4/HS3...
[2019-10-25 7:11:04 AM] HS3 Detected, Continue...
07:11:04:4201:[Pushover 3P]->HS3 Detected, Continue...
[2019-10-25 7:11:04 AM] ****** InitIO Ended ******
07:11:04:7881:[Starting Plug-In]->Plugin Pushover 3P started successfully in 902 milliseconds
[2019-10-25 7:11:05 AM] BackGround Thread Started
07:11:05:2997:[Pushover 3P]->CreateTable Entered
[2019-10-25 7:11:05 AM] AddToTable : Plugin Started Row Count: 0
[2019-10-25 7:11:10 AM] RegisterWebPage Called: PushConfig - Configuration - Pushover 3P Configuration
07:11:10:5650:[Pushover 3P]->RegisterWebPage Called: PushConfig - Configuration - Pushover 3P Configuration
[2019-10-25 7:11:10 AM] User Key: N/K
[2019-10-25 7:11:10 AM] Emergency Expiry: 0
[2019-10-25 7:11:10 AM] Emergency Interval: 0
[2019-10-25 7:11:10 AM] No User Key Specified, please enter in config page
07:11:10:9460:[Pushover 3P]->No User Key Specified, please enter in config page
[2019-10-25 7:11:19 AM] Found Plugin Devices, Exit
[2019-10-25 7:11:20 AM] End Of Enumerator - Create Devices False
[2019-10-25 7:11:29 AM] Devices Owned By Plugin 83 Name: Pushover 3P Root Device
[2019-10-25 7:11:29 AM] Devices Owned By Plugin 84 Name: Pushover 3P Enabled/Disabled
[2019-10-25 7:11:29 AM] Devices Owned By Plugin 85 Name: Pushover 3P Last Message Sent
[2019-10-25 7:11:29 AM] Devices Owned By Plugin 86 Name: Pushover 3P Disable Non-Emergency Messages
[2019-10-25 7:11:30 AM] Devices Owned By Plugin 87 Name: Pushover 3P Application Messages Remaining
[2019-10-25 7:11:30 AM] Array bCode(0) - 83
[2019-10-25 7:11:30 AM] Array bCode(1) - 84
[2019-10-25 7:11:30 AM] Array bCode(2) - 85
[2019-10-25 7:11:30 AM] Array bCode(3) - 86
[2019-10-25 7:11:30 AM] Array bCode(4) - 87
[2019-10-25 7:11:30 AM] Sending Status True Device Value: 100
07:11:30:7185:[Pushover 3P]->Sending Status True Device Value: 100
[2019-10-25 7:11:30 AM] Starting Flood Control Timer
07:11:30:9011:[Pushover 3P]->Starting Flood Control Timer
[2019-10-25 7:11:31 AM] Glance Message Delay Value 20
07:11:31:1104:[Pushover 3P]->Glance Message Delay Value 20
[2019-10-25 7:11:31 AM] Worker Thread Completed
[2019-10-25 7:12:45 AM] GetPagePlugin Called
any ideas1 Photo
Originally posted by Ravell View PostHS3 running on a Pi Linux Version (Standard Lic)
any ideas
Just a heads-up for Pushover users. I noticed a delay in notifications for the past couple of days, just some erratic behavior in general, and I had to re-register a couple of devices due to DDoS attacks on their server. Explained here for those interested: https://blog.pushover.net/posts/2019...25-ddos-attack
- 1 like
Originally posted by mrhappy View Post
Have you tried directly by the IP address rather than by MyHS? It might behave the same but this error is particularly vague and unhelpful so I don't really know where to start. Did you build the Pi and install the packages yourself or have you purchased it from HS? Do other plugin config pages work OK?
yes I never use myhs.. always direct shell or a local pc. I did not have really have a need for push notifs. so can go on without it. ill reach back out when i do get around to reinstalling it. I have a twillio account so may possibly down the roads use that for sms notif. Thanks mrHappy enjoy the weekend. PS yea it a pi i built and installed raspbian then HS3
Ahh right, yea I was trying everything I don’t even remember taking that screen capture but more than likely trying it from my office .. however local or remotely same error.. hmm wonder What library I could be missing.. I’ll try a fresh install shortly (over next few days) and report back in, I like that I can pop in a new micro sd card and start over if no progress pop the old one back in
Strange one - but you can try and add it manually. Try the following;
1) Stop the plugin
2) Open your HS3PushoverConf.ini file which is in your \Config directory
3) If you don't have an [APITokens] section then add this to the bottom of the file
4) Then enter a key like this appname=appkey and save the file
5) Restart the plugin, see if the application name is now in the event actions
It should look something like this;
Code:[Settings] UsrKey=KWnsGKueetY17to66uAypaJn6xxxxx eInterval=60 eExpiry=200 WantDevices=False FloodNumber=50 [Clients] iPad=removed nexus7=removed iPhone=removed redminote4=removed cttiphone=removed honor9lite=Nothing [APITokens] HomeSeer=cJvZXLNqBGifwKv2AcqfR5namxxxxx default=cJvZXLNqBGifwKv2AcqfR5namxxxxx
Great plugin so far!!
Originally posted by jdee View PostI have a search but came up with nothing so apologise if this is somewhere in this 78 page thread..... wondering what happens if the internet is down, does this plug-in retry until it succeeds or is there a simple way to achieve this via Homeseer?!
- 1 like
You could use this plugin via a script, and if the send fails, continue to try until it succeeds. That will only work for you if the plugin function returns failure information, which I am not sure about as I have not tried.HomeSeer 3, Insteon, Z-wave, USB-UIRT, Google Hub/Chromecasts/Smart Speakers, Foscam cameras, Amcrest camera, RCA HSDB2a doorbell
Great plugin and thank you!
I will see if I can put in a timer or queue if I get a web timeout exception and add the message to a list for periodic retrying.
- 2 likes
It's a fair point to raise and one I had not really thought about since the plugin was made all those years ago as I probably had the naive belief that most people would have a connection that is relatively stable or have some sort of backup. At the minute all that will happen is that the message will not go and you will get an error in the log, it will not try to send it again.
Only recently started with Homeseer and looking at its potential to be a mini intruder system, notifying me when sensors are triggered, and came across this plugin. My Homeseer is on a UPS but modem/router isn't (will add one down the track) hence was just a thought to ensure best possible receiving a notification.
Mr Happy
I hope you can help me. It seems HS3 stopped pushing the pushover messages to my device clients. This may have stopped a few days ago. I made no changes to the PI or to my account. I test from the pusher website it works fine to my clients.
I test an event in HS3 and it logs the pushover message in the PI config as if it went out. Just not getting to my device(s).
Is there something I can do to reset this? Of course I just noticed it is not working now that I preparing to go away for the next few days
