Sending from HomeSeer isn't working for me either. Same ssl/tls error.
HS3 Pushover Plugin
HomeSeer 3, Insteon, Z-wave, USB-UIRT, Google Hub/Chromecasts/Smart Speakers, Foscam cameras, Amcrest camera, RCA HSDB2a doorbell
A note to those worried about pushover and HS4. It should be straightforward to use the Big5 plugin to post messages directly to pushover. This would require getting a token for your own app (as I understand their policy). Big5 has the string building tools of .NET. So probably no need for a Pushover specific plugin or other scripting.
I use Big 5 to get 5 minute prices from my electric utility. Homeseer uses those prices to decide when to run my steam humidifier in winter, and dehumidifers in summer.
Originally posted by dmiller View PostAnyone have a link to the Homeseer documentation for this plugin? The link on the plugin is dead. If I can figure out how to create a device I should be good to go.
- 1 like
I have just installed this on the weekend and I did some test messages which worked fine. Today I am trying the test with variables in the message but it isn't sending any message. I took the variable out and it still isn't sending any messages. I am getting an error in the log:
Mar-18 9:19:26 AM Pushover 3P Unknown Exception in Pushmessage Object reference not set to an instance of an object.
Originally posted by pcgirl65 View PostI have just installed this on the weekend and I did some test messages which worked fine. Today I am trying the test with variables in the message but it isn't sending any message. I took the variable out and it still isn't sending any messages. I am getting an error in the log:
pcgirl65 what version of PI are you running ? 0.0.0.47 or 48 ?
I just updated to 0.0.0.48 and I ran an event with a pushover including a variable and it works fine on my side.
have you tried building a completely new event and retry if you still have the problem ?
Have you tried disabling, remove and re-install ?
HA! I am using 0.0.0.48. I deleted the test event and did a new one and it did work! So how come it didn't work with the other test event? j Also, if I want to send a pushover with the devices name in the message, how do I do that. So for instance, I have an event that when someone arrives home it will turn on the heat and send a pushover message that they are home. How do I include the name of the device that has arrived home?
