Originally posted by Ronnie
View Post
HS3 Pushover Plugin
I'd like to install this plug-in but I can't seem to find a list of the plugins that can be installed on HS3. I know I used to be able to see a long list of available plug-ins but can't find the list now.
I looked under "Manage Plug-ins" in HS3 and clicked on "Additional Interfaces" and "update Listing", but no plug-ins show up.
I've tried Chrome and Edge. What am I doing wrong?
That sort of tells me that you don't have a connection to the internet or the HST servers. What version of HS3 are you running?
Here is what I see, maybe Rupp might be able to figure out why the plugins aren't showing. From what I understand the entire list comes from the HST servers.
You can see just a partial glimpse of the all the categories and if you expand them there are quite a few under each.
Do you have that machine firewalled or not registered on the HST servers?
g
Originally posted by jon00 View PostDo you have a file called updater_override.txt in your Homeseer root folder? If so, delete that and try again.
Thank you for help people !!
Frank
Originally posted by George View PostIf you manually installed a plugin or got a plugin directly from an author, the updater_override file contains the directives to install the plugin and where to put the different files.
In your case, do you ever remember installing a beta or test version of the Alexa plugin?
Had you seen that happen before?
Originally posted by mrhappy View PostFair point, they both are in the same function (a logging function, determine the OS type to determine the path structure and then get the HS path to determine where put the log files) so can be changed and in hindsight I think I put them there in a rush as I can see they are going to be called constantly.
There is only one thread in the plugin so that narrows it down somewhat. Most of the code inside that thread is not particularly contentious apart from me running through the enumerator and registering a web page. It registers the web page first then runs, does a bit more like sets up some timers and then through the enumerator to determine whether or not the plugin has devices. I've seen your other posts and from what I can understand I think I will need to check those calls are appropriately safeguarded.
It may be that I can get rid of the enumerator alltogether and like others I am a bit mystified that it takes as long as it takes. I was always a bit surprised that a simple call of something like hs.getplugindevices (where you pass in a plugin name and instance) was not written instead, I remember that in the HS3 developer webinar there was some discussion over the enumerator and I think it was originally not part of the HS3 spec and only added after some protest.
I have been using the v3 of the app on v4 of homeseer (windows) it works great, It is a shame the is no v4 of the program, easy to use and just plain works
Does anyone use pushover in the Weather XML plugin from CFGuy? I have an alert trigger action that sends out a pushover message to some users and it used to work fine. I just noticed this morning that the WeatherXML plugin did not send me any messages. I'm not sure how long it hasn't been working because we haven't had any severe weather since last fall that would have triggered an alert. I know the alert in weatherXML is working ok because my speakers play the correct alert message.
