I recently setup my z-wave network on HS3 (HS3 V3.0.0.54, zwave V3.0.0.60 using a z-troller interface). Setting up 19 wired was quick and painless. (I wired each into a custom pluggable electrical box near the interface and added each to the network using the HS3 add node function). After installing each device in correct location in the house, I did 4x optimizations of the network.
Then I acquired an everspring (home mangeables) ST814-2 sensor (thanks gmcafoos...I think). I reset the sensor (c/f 3x, followed by holding down c/f until beep stops), then went to the trusty add node function in the controller dropdown of the z-wave plugin, hit start, then put sensor in inclusion mode (c/f 3x). It seems to add, and creates 3 child devices (battery, temp, humidity). The problem is no child devices get updated, and the root device does not seem to be able to communicate with HS3.
After searching on the board, it looks like many have problems with battery powered z-wave, and specifically everspring sensors in hs3. Many posts report being able to add, but then child devices not updated. Are there any that have gotten everspring sensors to work with HS3? I only see correct settings for hs2.
Perhaps the ease of wired z-wave setup has spoiled me for configuring battery powered z-wave. So far I have spent more time on this one device, than on the 19 wired devices total, and it still does not work. What am I missing?
