At the moment I am trying to get my head arround the HS3 event logic.
One thing I am trying to do right now is use the status of a light in a room to determine if the room is used by someone at that moment.
For example, if the lights in the bathroom are On (and with On I mean On or Dimmed) for longer than two minutes then I assume that someone is taking a shower. Based on the fact that the bathroom is in use I want to do some actions like turn on the fan and bathroom TV.
Now when I look at the " been/for at least" "and "been/for exactly" (not sure what the exact difference is between the two) triggers I am unable to put in a range that represents all value's but off. I think this something that I would need if I want to trigger on every possible Dim level.
I could do a delayed trigger using " this device has its value set and is not equal to off" But then I would need to build in event logic that terminates this delayed event when the light turned off within two minutes. Because than I assume that someone whas in the Bathroom just to grab something, and not to take a shower or a bath.
At the moment I don't find most of the event triggers al that self explanatory, so some more detailed documentation on them would be very welcome if you asked me..
thanks for thinking with me on this one..
Martijn.
Martijn.
