Originally posted by mrhappy
View Post
results = System.Diagnostics.Process.Start("C:\Program Files (x86)\Homeseer HS3\HS3EventRun.exe eventname='Test Event'")
And perhaps a better way to run the event from the compiled program is to include the vb piece of your source code for "HS3EventRun.exe" rather than the .exe app. I think that is what you mean by "embed that code into VB to start with". But I haven't got that piece figured out.
I know that Rich's JSON/vb.net example accomplishes this goal, but I haven't quite distilled it down far enough to find the appropriate syntax to execute a JSON command from a vb.net compiled program. Most likely your 'HS3EventRun' uses similar source code to Rich's example (??)
Does that make sense?
I appreciate the guidance with this MH.
