I noticed that ZIR000 motion sensors no longer work in HS3. I see some motion and no motion updates in the logs but the home screen does not reflect this. I also noticed that the updates in the logs come from the root node and not from the motion child node. It seems like HS3 has the root and child node in reverse order. Please advise.
ZIR000
Originally posted by CodeSavant View PostI noticed that ZIR000 motion sensors no longer work in HS3. I see some motion and no motion updates in the logs but the home screen does not reflect this.Regards,
Rick Tinker (a.k.a. "Tink")
Logs
Here's my logs where it shows that the motion/no motion triggers are occurring at the root level instead of the child:
Device: Nook Ground Motion Sensor Root Status set to OFF/CLOSED/NO MOTION
Device: Nook Ground Motion Sensor Root Status set to ON/OPEN/MOTION
Rick, I took your suggestion further and actually removed the entire node and re-added it back and still no dice.
I'm looking forward to this fix.
Thanks!
Well I'm afraid I cannot fix it without knowing what is failing here. It is an ancient device and I do not have one around, so I need to have the log from when the device was scanned/added - those two entries showing the control only confirm the issue. The log from when it was scanned or imported would show manufacturer information, errors, issues, etc. which I can then use to fix the issue. If that is not enough, then I will find one or get one to work with, but I need to first see the log to know if there is an issue I can address right away.
Open a Bugzilla ticket and add the log lines to the ticket.Regards,
