ST814-2 Not Working
  • ST814-2 Not Working
    Struggled to get node added. All devices did not install. Tried severaltimes and got success.
    No Status
    First Living Room Electronic Rack Sensor 014CDE83-089 Z
    Wave
    Multilevel
    Sensor
    Root
    Device
    20 %
    First Living Room Electronic Rack Humidity 014CDE83-089-Q34 Z-Wave Relative Humidity Today
    3:52:50 PM 100%
    First Living Room Electronic Rack Battery 014CDE83-089-Q35 Z-Wave Battery Today
    3:51:49 PM 84.9 F
    First Living Room Electronic Rack Temperature 014CDE83-089-Q36 Z-Wave Temperature Today
    3:53:10 PM
    HS3 not recognizing devices ... (from log)
    May-13 16:04:27 Z-Wave Error Node Change Event for Node 89 on Network 014CDE83, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V2 but no valid devices were found. (31-05-05-01-19-85) May-13 16:04:27 Z-Wave Error Node Change Event for Node 89 on Network 014CDE83, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V2 but no valid devices were found. (31-05-01-2A-03-41-F5) May-13 16:04:27 Z-Wave Error Node Change Event for Node 89 on Network 014CDE83, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V2 but no valid devices were found. (31-05-01-2A-03-41-F5) May-13 16:02:31 Z-Wave Error Node Change Event for Node 89 on Network 014CDE83, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V2 but no valid devices were found. (31-05-05-01-14-88) May-13 16:02:30 Z-Wave Error Node Change Event for Node 89 on Network 014CDE83, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V2 but no valid devices were found. (31-05-01-2A-03-42-F6) May-13 16:02:30 Z-Wave Error Node Change Event for Node 89 on Network 014CDE83, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V2 but no valid devices were found. (31-05-01-2A-03-42-F6)
    Has anybody managed to get Everspring ST814 up running at HS3?
      I just ordered 1.... I hope so, will let you know
      lottsa changes from date of your post
      Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro
        I added one to my network yesterday, and have the same problem - the ZWave child devices are created, the first update for temperature/humidity works during that scan (or rescan), but after that every status report from the Everspring is logged as an error (already added my experience to the existing Bug report). Everspring is Node 7 below, configured to report when temperature changes by 2 degrees.
        May-28 1:31:26 AM Z-Wave Error Node Change Event for Node 7 on Network 016A2698, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V3 but no valid devices were found. (31-05-05-01-5A-98)
        May-28 1:31:26 AM Z-Wave Error Node Change Event for Node 7 on Network 016A2698, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V3 but no valid devices were found. (31-05-01-2A-02-A8)
        May-28 1:31:25 AM Z-Wave ZStick: Z-Wave Wake-Up Notification Received for Node 7
        May-28 1:15:00 AM Log Info The log database is currently 0.27MB in size.
        May-28 12:38:32 AM Z-Wave Error Node Change Event for Node 7 on Network 016A2698, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V3 but no valid devices were found. (31-05-05-01-5A-98)
        May-28 12:38:32 AM Z-Wave Error Node Change Event for Node 7 on Network 016A2698, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V3 but no valid devices were found. (31-05-01-2A-02-A8)
        May-28 12:38:31 AM Z-Wave ZStick: Z-Wave Wake-Up Notification Received for Node 7
        May-27 11:45:38 PM Z-Wave Error Node Change Event for Node 7 on Network 016A2698, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V3 but no valid devices were found. (31-05-05-01-5A-98)
        May-27 11:45:37 PM Z-Wave Error Node Change Event for Node 7 on Network 016A2698, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V3 but no valid devices were found. (31-05-01-2A-02-A8)
        May-27 11:45:36 PM Z-Wave ZStick: Z-Wave Wake-Up Notification Received for Node 7
        May-27 10:52:44 PM Z-Wave Error Node Change Event for Node 7 on Network 016A2698, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V3 but no valid devices were found. (31-05-05-01-5A-98)
        May-27 10:52:43 PM Z-Wave Error Node Change Event for Node 7 on Network 016A2698, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V3 but no valid devices were found. (31-05-01-2A-02-A9)
        May-27 10:52:43 PM Z-Wave ZStick: Z-Wave Wake-Up Notification Received for Node 7
        May-27 10:15:00 PM Log Info The log database is currently 0.27MB in size.
        May-27 9:59:50 PM Z-Wave Error Node Change Event for Node 7 on Network 016A2698, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V3 but no valid devices were found. (31-05-05-01-5A-98)
        May-27 9:59:50 PM Z-Wave Error Node Change Event for Node 7 on Network 016A2698, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V3 but no valid devices were found. (31-05-01-2A-02-AB)
        May-27 9:59:49 PM Z-Wave ZStick: Z-Wave Wake-Up Notification Received for Node 7
        May-27 9:55:35 PM Z-Wave Device: Kitchen Counter Lights Set to OFF
        May-27 9:06:57 PM Z-Wave Error Node Change Event for Node 7 on Network 016A2698, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V3 but no valid devices were found. (31-05-05-01-5A-98)
        May-27 9:06:56 PM Z-Wave Error Node Change Event for Node 7 on Network 016A2698, CC=COMMAND_CLASS_SENSOR_MULTILEVEL_V3 but no valid devices were found. (31-05-01-2A-02-B1)
        May-27 9:06:55 PM Z-Wave ZStick: Z-Wave Wake-Up Notification Received for Node 7
        May-27 8:14:03 PM Z-Wave 4 out of 4 Child devices of node 7 were created successfully.
        May-27 8:14:02 PM Z-Wave Setting wake-up interval for device Z-Wave Interface Sigma Multilevel Sensor Node 7 to 1 hours and 0 minutes.
        May-27 8:14:02 PM Z-Wave Programming device Z-Wave Interface Sigma Multilevel Sensor Node 7 (7) to send wake-up notifications to HomeSeer.
        May-27 8:14:02 PM Z-Wave Node 7 supports the Wake-Up Command Class Version 2 - Capabilities were retrieved successfully.
        May-27 8:14:02 PM Z-Wave Device: Z-Wave Interface Everspring Relative Humidity Node 7 Child EP2 Set to 90 (%)
        May-27 8:14:01 PM Z-Wave Device: Z-Wave Interface Everspring Temperature Node 7 Child EP1 Set to 69.8 (F)
        May-27 8:14:01 PM Z-Wave Processing Information for Node 7 Multi-CHANNEL Command Class of SENSOR_MULTILEVEL_V3, Endpoint 2
        May-27 8:14:00 PM Z-Wave Processing Information for Node 7 Multi-CHANNEL Command Class of SENSOR_MULTILEVEL_V3, Endpoint 1
        May-27 8:14:00 PM Z-Wave All associations for node 7 have been retrieved successfully, it supports associations on these groups: 1, 2.
        May-27 8:14:00 PM Z-Wave Node 7 Association Group 2 can have 3 associations, and currently has 0
        May-27 8:14:00 PM Z-Wave Node 7 Association Group 1 can have 1 associations, and currently has 1
        May-27 8:13:59 PM Z-Wave Getting association information for node 7
        May-27 8:13:59 PM Z-Wave Node 7 is Z-Wave version: Lib: 3.52 App: 2.1
        May-27 8:13:59 PM Z-Wave Node: 7 Supports Class(es): SENSOR_MULTILEVEL_V3, MULTI_CHANNEL_V3, VERSION_V2, MANUFACTURER_SPECIFIC_V2, ASSOCIATION, WAKE_UP_V2, BATTERY, CONFIGURATION, BASIC, NOTIFICATION_V4
        May-27 8:13:59 PM Z-Wave Device synchronization needs to create 1 device.
        May-27 8:13:59 PM Z-Wave Device synchronization does not need to create any new devices.
        May-27 8:13:59 PM Z-Wave Syncing Z-Wave nodes with device list...
        May-27 8:13:59 PM Z-Wave Found 7 Z-Wave nodes
        May-27 8:13:59 PM Z-Wave Getting Z-Wave node list for network 016A2698...
          strange install for me..
          could not get HS to add node, but was able to add thru controller add button..
          it is in and working but throws
            and devices ...
              We are working on the problem with the ST814-2. Everspring is not sending the unsolicited commands correctly, so if you program it to send temperature or humidity automatically upon change, you will get the messages in the log. The reports are not being sent in a multi-channel encapsulation which the plug-in is expecting, since the device uses multi-channel. We have to code a workaround that uses the report type (temperature or humidity) to find the HomeSeer device since the channel number is not there. It should not have passed certification with this flaw but it is what it is. An earlier version of the device did not have this issue.
              As a workaround for now, you can set the wake-up interval to a shorter value and use polling on the temperature and humidity child devices to get the value. e.g. Wake-Up set to 20 minutes and polling set to 10 minutes should guarantee one update every 20 minutes to the temperature and humidity.
              Rick Tinker (a.k.a. "Tink")
                Thanks Rick !
                  ST812/HS 3.0.0.96
                  Ditto the problems with the ST812 not updating, despite all kinds of playing around with polling, wake-up, auto-report interval, and auto-report T/H changes (the latter 2 definitely don't appear to work). I don't know if I've set the wake-up > polling, doing that now, but I'd like the auto-report on T/H change to work...
                    Tried all night to get any of the 3 ST814's I have to work with multiple combinations of polling, auto-report and wakeup intervals. Nothing works- I only get the initial set of values and no updates.
                    I pulled batteries and set params immediately, as well as reset params on existing connected units (pain in the you-know to keep pressing the button 3x on that), no variation in results.
                    Help?
                      A new Beta version (158) of the ZWave plug-in is available in the "Beta" section of HS3 Updater, specifically to address the ST814 problem. (Relayed from the Bug Report that's been tracking this issue).
                      If anyone knows how to obtain and copy that file onto a Zee, let me know...
                        still doing this on one of the 3 st 814 and some times on sm 103
                        still doing this on one of the 3 st 814 and some times on sm 103?
                        I have 3 temp sensors in different parts of the property and one of them still is sending same errors. I have the lates .58 z wave driver installed?
                          Can anyone confirm or deny if this issue has been resolved?
                          Randy Prade
                          Aurora, CO
                          Prades.net
                            I've just tested the sensor with zwave beta plugin 3.0.0.168 and the humidity and temperature readings are updated.
                            I cannot confirm the battery status yet since it has a longer interval.
                              After I removed one trouble-making sensor, I've been running two without any errors for several weeks
                              Zee version 3.0.0.106
