HS3 as Service (Windows)
  • #16
    Originally posted by Shodan View Post
    Hello,
    How do you close HS3 in the normal way when it is started from the task scheduler at startup ?
    Thank you !
    HS3 was not designed to be launched this way, so there is no way to 'normally' close it. You would need to kill the process.
    • #17
      There are a couple of plugins around that will shut down HS and you could also shut down HS by issuing the hs.shutdown script command.
      Cheers
      Al
      HS 3.0.0.548: 1976 Devices 1156 Events
      Z-Wave 3.0.1.262: 123 Nodes on one Z-Net
      • #18
        Thanks Sparkman,
        I should have thought about it !
        Anyway, it would be nice to have a "shutdown" command in the webserver menu, just like the Hs3 Linux version has (if I remember correctly)
        • #19
          Thanks Sparkman,
          You're welcome. You could always use this to add a menu command: http://board.homeseer.com/showthread.php?t=163963.
          Cheers
          Al
          • #20
            Are you saying HS3 does not voluntarily respond to these shutdown requests:
            • Control-C
            • Send WM_CLOSE to windows (not applicable in most situations, but still wondering)
            • Post WM_QUIT to threads
            • Terminate process (drastic and does not provide for orderly shutdown of HS3)
            I admit I have a bias (those 'terminator' features point to a specific product), but still would like to have those validated.
            • #21
              Have a look at I Think Jon00 plugin has one to shutdown
              • #22
                You should install Windows updates manually on your HomeSeer system. That will give you more control over this kind of thing.
                Yeah, Windows 10 doesn't give you a lot of control over that these days.
                G
                • #23
                  G
                  If you want to make Windows 10 not automatically apply updates, you can change your connection to 'metered'. This will cause it to not download updates automatically. Normally you can only change wireless connections to metered. However, here are instructions for changing your wired connection to wireless.
                  My internet connection is in fact metered since I am on satellite. A big windows update would kill my data cap so I set to metered. I have a 'free' window between midnight and 5am that I can use to download big items if I need to.
                  https://www.cnet.com/how-to/meter-yo...in-windows-10/
                  • #24
                    Here is another possible solution
                    http://board.homeseer.com/showthread.php?t=185991
                    • #25
                      Or you can just go to Windows services and disable Windows Update.
