I have looked at the various post regarding installing Homeseer. One described using 2 different links to the Homeseer downloads page and another listed only 1.
All 3 links were different. Do I understand correctly that the way to install software like this is to add the link to the sources.list file and then sudo apt-get install ? Which link or links?
cesarvog's suggestion of editing this file has revealed a possible error on my end. I do not seem to have this folder. when I enter sudo nano /usr/local/homeseer or /user/local/homeseer/speak.sh it tries to create a new folder by that name instead of opening an existing folder. I suspect that this problem may prevent homeseer from installing properly.
Regarding sound, you don't need to give it up. I found out that all you have to do is use nano to edit 'speak.sh', which should be in /usr/local/Homeseer.
Your edited file should look like this:
#!/bin/sh
flite -voice kal16 -t "$1"
#pico2wave -w=temp.wav "$1"
#aplay temp.wav
John
#!/bin/sh
#aplay temp.wav
John
