How does HS3 deal with Yale Z-wave locks - will it log events (someone entering right combination, or wrong combination), and can the locks be locked/unlocked as an Action from the HS3 system?
Yale Z-wave locks?
Originally posted by mlevin77 View PostHow does HS3 deal with Yale Z-wave locks - will it log events (someone entering right combination, or wrong combination), and can the locks be locked/unlocked as an Action from the HS3 system?
Cheers
Al
PS I have a script posted to the board here that can help with managing the info from the locks.HS 3.0.0.548: 1990 Devices 1172 Events
great! Now, I've got the lock added, but it shows up under Devices as a single line, with the icon grayed out saying "off" - no obvious way to see or control any of its functions. Is that normal? Where are its information and control functions? Or do I need your script to be able to see/control it?
No, that's not normal (although many people have experienced the same issue). Did you add the lock when it was really close (within inches) from your controller? Rescan the lock a few times and if you still don't have multiple devices created, post the HS3 log info from the rescan attempts.
Cheers
AlHS 3.0.0.548: 1990 Devices 1172 Events
Originally posted by sparkman View PostNo, that's not normal (although many people have experienced the same issue). Did you add the lock when it was really close (within inches) from your controller? Rescan the lock a few times and if you still don't have multiple devices created, post the HS3 log info from the rescan attempts. Cheers Al
You don't need to remove it from HS, but you need to remove the lock from the door and bring the lock to the stick while it's plugged in and then rescan from HS from the z-wave controller plugin page. Bringing the stick to the lock won't work.
Cheers
Originally posted by sparkman View PostYou don't need to remove it from HS, but you need to remove the lock from the door and bring the lock to the stick while it's plugged in and then rescan from HS from the z-wave controller plugin page. Bringing the stick to the lock won't work.
Negotiating or Verifying SECURITY SCHEME for node 3
Warning: Failed to get a SECURITY SCHEME or verify the key from node 3. Device may not be added properly to HomeSeer.
Warning: The security device may have a timeout when adding to the network, bring the device close to HomeSeer and use the Add Node button to add it (remove it first)
Warning: If this device was previously added to the network, the device may need to be removed from the network and re-added.
Warning: In case the device was previously added successfully, an attempt will be made to continue the import.
Getting SECURITY class information for node 3
Error: Security class information is NOT present - cannot continue loading node 3Last edited by mlevin77; August 11, 2015, 05:11 AM.
Originally posted by Rupp View PostThe long USB cable "may" work depending on the length. USB signals degrade fast on longer cables.Last edited by mlevin77; August 16, 2015, 02:10 PM.
Glad that worked for you. Beats having to remove the lock
I don't believe there's a good guide on all the features. You can explore the functionality by clicking on the notification child device and then the Status Graphics tab. There you will see a list of items that will be logged that you can trigger events on. What I use is create a script that runs on any change on the notification device and will take different actions. You can create individual events, but I found the script an easier way to go, especially if you have (or will have) multiple locks. A link to the script is in my original reply above.
Cheers
Originally posted by sparkman View PostGlad that worked for you. Beats having to remove the lock
Cheers
Al
Does your Yale lock report the remaining battery percentage correctly? Mine has been installed for 40 days and still at 100%. Its used 2-3 times a day.
I have read old posts that there were issues with battery reporting. Seems to good to be true and hate to find out the hard way.
Will
Will
The script only reports on low battery alarms in the notification device. It does not report battery values otherwise. Are you polling the lock battery device periodically?
Cheers
Cheers
Al
Originally posted by will40 View PostYes, I have Assa Abloy Entry Control Node 11 Root Battery polling every 12 hours.
Cheers
