TCP/UDP plugin ?
    TCP/UDP plugin ?
    Hi ALL
    I recall there was a TCP/UDP plugin for HS ie: listener and sender. If its still available, is it HS3 compatible ?
    Reacquainting myself with HS3 after a VERY LONG break :-)
    Thankyou..Pete
    HS 2.2.0.11
    Hi Pete, is this what you are thinking of: http://board.homeseer.com/showthread.php?t=169753. There's a HS2 version of it as well: http://board.homeseer.com/showthread.php?t=155438.
    Cheers
    Al
      Cheers
      Al
      Thanks mate, absolutely PERFECT :-)
      Ripper of a plugin, time to code the arduino up and throw some packets at HS :-)
      HS 2.2.0.11
        ... then why not just use the Arduino plugin in the first place?
          I want to experiment myself with UDP packets and learn a little :-)
          I have the arduino plugin, it works very well but I want to branch out :-)
          HS 2.2.0.11
            Ah, OK then. It's always fun to learn new stuff!
