Stop Energy DB filing Log File???
  • Stop Energy DB filing Log File???
    My system is stabilizing enough that some log entries are annoying. Especially the many entries, every few hours, to tell me the Energy Database is compacting. I'm not sure why this is useful(never fails or provides useful information).
    Is there a way to stop the Energy Database compaction logging???
    BobSpen
    Did this ever get resolved?
    Plug-Ins Enabled:
      wpiman,
      I forgot all about this, but I don't see the messages anymore. Don't know if I did something(don't think so) or a HS newer version eliminated the messages??????
      BobSpen
        Does anyone know if this can be turned off, the output is quite verbose and happening avery 30 mins, I'd like to disable the logging of these events.
          If you don't use it you can disable it on the tab General of Setup ("Enable Energy Logging and Graphing"). This will stop not only the logging but also the graphing, it was better if the two was separate!!!
            I’m not sure how you’d be able to graph unless you had data logged...
              I think the post was about the regular "Compacting data older than..." messages in the event log every four hours. It Is actually quite annoying and useless information.
                Yes, but the logging in the setting refers to logging energy data to a database, not logging warnings/errors/info to the HS log.
                  LOl. Which leads us back to the original post. Probable answer is "No".
                    I was thinking some kind of option that disable the logging to be show in the HS log. Just like the same we have for devices, events...
                      Understood, thanks. I thought you were referring to the logging of data, not the logging of warnings, etc. to the HS log.
                        No problem
                        I think that option it's what the user's in this tread wanted for. The only option that exists disable all.
