Image file does not exist, returning blank image: C:\Program Files (x86)\HomeSeer HS
    Hi,
    I keep seeing " Image file does not exist, returning blank image: C:\Program Files (x86)\HomeSeer HS3\html\0" in the HS3 Log.
    Does anyone know how to tell what this is related to?
    Log below:
    Apr-04 09:43:22 Informational Host F8-72-EA-94-E9-98 changed from 192.168.1.1 to 10.0.0.2
    Apr-04 09:42:18 Informational Host F8-72-EA-94-E9-98 changed from 10.0.0.2 to 192.168.1.1
    Apr-04 09:42:00 Warning Image file does not exist, returning blank image: C:\Program Files (x86)\HomeSeer HS3\html\0
    Apr-04 09:41:04 Warning Image file does not exist, returning blank image: C:\Program Files (x86)\HomeSeer HS3\html\0
    Apr-04 09:41:03 Warning Image file does not exist, returning blank image: C:\Program Files (x86)\HomeSeer HS3\html\0
    Apr-04 09:40:11 Warning No response/improper response from GC-100-06 [192.168.1.35] to command 'get_IR,2:3'
    Apr-04 09:40:08 Informational Watchdog Timer reconnect attempt succeeded.
    Apr-04 09:40:08 Informational Ethernet connection established to 192.168.1.35:4998
    Apr-04 09:40:08 Warning Watchdog Timer indicates TCP connection to Global Cache device [192.168.1.35] was lost.. Attempting to reconnect ...
    Apr-04 09:40:03 Warning Image file does not exist, returning blank image: C:\Program Files (x86)\HomeSeer HS3\html\0
    Apr-04 09:38:00 Warning Image file does not exist, returning blank image: C:\Program Files (x86)\HomeSeer HS3\html\0
    Apr-04 09:37:59 Warning Image file does not exist, returning blank image: C:\Program Files (x86)\HomeSeer HS3\html\0
    Apr-04 09:37:04 Warning Image file does not exist, returning blank image: C:\Program Files (x86)\HomeSeer HS3\html\0
    Apr-04 09:36:00 Warning Image file does not exist, returning blank image: C:\Program Files (x86)\HomeSeer HS3\html\0
    Apr-04 09:35:11 Warning No response/improper response from GC-100-06 [192.168.1.35] to command 'get_IR,2:3'
    Apr-04 09:35:10 Warning No response/improper response from GC-100-06 [192.168.1.35] to command 'get_IR,2:3'
    Apr-04 09:35:08 Informational Watchdog Timer reconnect attempt succeeded.
    Apr-04 09:35:08 Informational Ethernet connection established to 192.168.1.35:4998
    Apr-04 09:35:08 Warning Watchdog Timer indicates TCP connection to Global Cache device [192.168.1.35] was lost.. Attempting to reconnect ...
    Apr-04 09:34:30 Warning In ProcessEventItem, Cannot process event Jon00s Check Email, there are no actions.
    Apr-04 09:34:24 Informational Host F8-72-EA-94-E9-98 changed from 192.168.1.1 to 10.0.0.2
    Apr-04 09:34:22 email Email successfully sent to Alerts@sh.org
    Apr-04 09:34:18 Informational Discovered host 192.168.1.160 [] [F0-F6-1C-BF-A3-2A] on 192.168.1.0.
    Apr-04 09:34:01 Warning Image file does not exist, returning blank image: C:\Program Files (x86)\HomeSeer HS3\html\0
    Apr-04 09:33:17 Informational Host F8-72-EA-94-E9-98 changed from 10.0.0.2 to 192.168.1.1
    Hi Sonny,
    Have you seen this thread: http://board.homeseer.com/showthread.php?t=180674.
    Cheers
    Al
    HS 4.2.8.0: 2134 Devices 1252 Events
    Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
