I have an series of events which utilize the group conditions capability and worked last pond season. I use this to add liquid chlorine to a small waterfall pond use a timer to determine when the chlorine reservoir is nearing empty.
I've made a very simple event to troubleshoot the issue I am now having for which I have not changed since last season. When the check for "if the timer is less than X minutes" is in the group condition, the event will not trigger. While the same timer check as a event condition triggers as expected.
My setup:
HomeSeer Version: HS3 Pro Edition 3.0.0.280
Operating System: Microsoft Windows 8.1 Pro - Work Station
Enabled Plug-Ins
2.0.22.0: BLBackup
2.0.25.0: BLLAN
3.0.0.22: EasyTrigger
0.1.0.1: FitbitSeer
3.0.0.75: HSTouch Server
30.0.0.29: RFXCOM
3.0.0.49: weatherXML
3.0.1.66: Z-Wave
The following event configuration fails. Any thoughts as to what to fix? Thank you.
My setup:
Enabled Plug-Ins
2.0.22.0: BLBackup
2.0.25.0: BLLAN
0.1.0.1: FitbitSeer
30.0.0.29: RFXCOM
3.0.1.66: Z-Wave
