I had an unrelated call to the clients house today. The Homeseer app was unable to open the gate. The DoorBird app worked fine. After entry, I tried from the wall mount tablet, running HS3Touch, to open the gate. Again it failed So, I left it like that until I was able to get to my laptop to work on it.
I am able to wget the doorbird from the homeseer and receive the index.html. I cannot see a preview of the camera from the plugin.
The root device still shows a Communication Error. It does appear to register doorbell rings tho. I did not test that. I just see a new timestamp on that as well as the door closed.
Log entries on the HomeSeer are pasted below. I'm guessing the customer is trying the unlock on the touch panel at times. Then they probably use the shortcut to the doorbird app or their phone to open the gate.
A toggle of the plugin enable switch and everything is working again for now.
[TABLE] [TR] [TD]2019-10-24 17:01:29[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 17:01:14[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 17:00:28[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 13:33:53[/TD] [TD]Event[/TD] [TD]Event Trigger "TTS 908 Doorbird Front Gate"[/TD] [/TR] [TR] [TD]2019-10-24 13:02:08[/TD] [TD]Event[/TD] [TD]Event Trigger "TTS 908 Doorbird Front Gate"[/TD] [/TR] [TR] [TD]2019-10-24 12:00:18[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 12:00:13[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 12:00:08[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 12:00:03[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 11:59:58[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 11:59:53[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 11:59:48[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 11:27:46[/TD] [TD]Event[/TD] [TD]Event Trigger "TTS 908 Doorbird Front Gate"[/TD] [/TR] [TR] [TD]2019-10-24 10:40:24[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 10:21:03[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 10:20:57[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [TR] [TD]2019-10-24 10:20:50[/TD] [TD]DoorBird[/TD] [TD]DoorBird Web Exception: The operation has timed out.[/TD] [/TR] [/TABLE]
