The DoorBird is working again, all the schedules where gone in the DoorBird.
The button "Remove notification schedules" removes everything also the schedules DoorBird it self uses!! (in HS3)
mrhappy In version 0.0.0.24 ther e was a message Notification setup completed (or simalar) in version 0.0.0.30 it's gone, why?
HS4 it's working again, but HS3 still Not working good.
This error is in the Log when start the plugin:
DoorBird Web Exception: The operation has timed out.
Only if I make the HTTP rules in the DoorBird myself.
The DoorBird page load in HS3 takes a verry long time, and this errors are showed where the motion and doorbell images should show up:
Image 1 Failed To Download - Object reference not set to an instance of an object
Can you fix it
Can you fix it
