I have found a site which allows you to post sensor data from HS3 to the site and automatically create graphs.
The site is www.initialstate.com
Once you create an account, create a 'bucket' manually on the web site, get your Keys then, making use of it's REST API, publish the data using an Event to run an immediate script - for example:
&hs.URLAction "https://groker.initialstate.com/api/events?accessKey=YourAccessKey&bucketKey=YourBucketKey","POS T","Lounge="&HS.DeviceValueEx(160),""
This publishes my Lounge temperature in the graph attached. Publish another to the same bucket replacing Lounge with another room and the appropriate Device ID
You can stack graphs - in my case, I have the main room temps & outside temp against the Light levels - this way I can see how quickly the rooms heat up or cool down as the OAT changes.
I must thank Paul Ockenden for publishing details of this site in PCPro (UK)
Hope someone find this useful
Cheers
Scott
Cheers
Scott
