I'm trying to figure out the best way to setup a remote speaker client. Would be cool to have HS3 make announcements, a feature I don't use currently. I run HS3 Linux on a server in the basement as a VM so I was thinking of some kind of in wall speaker attached to maybe a raspberry pi behind the speaker in the wall. I can run the pi with POE for a single wire install. However, I never touched a raspberry pi before so if there is something more common or simple I'm all for easy.
Any recommendations? Does the pi running linux have any limitations vs a windows based speaker client?
Separate questions - if I had multiple speaker clients can they be used individually or does HS3 broadcast to all speaker clients?
