Easy way to get event ID?
  • Easy way to get event ID?
    I want to use JSON to run events by the ID number. Is there an easy way to get an event's ID number?
    Its just the event name ...
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.1.18 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
      You can also use this: http://board.homeseer.com/showthread.php?t=163299
      Jon
        Jon00EventList plugin
        I have tried the plugin to list events, with the purpose of being able to read the event ids.
        But the plugin just gives me a blank page.
        Homeseer 3.0.0.297 on Debian v8
        complete mono v1.6 installed
        Is it supposed to work in that configuration?
          mono v4.6 that is, no 1.6
            When you say blank, do you get anything displayed i.e the Homeseer logo bar, links etc? ASPX pages don't work on a Pi BTW.
            Jon
              Blank, like in blank. No bars, nothing.
              It does blnk out what ever I may have had in the browser window, so I do hit something in the HTTP server, no error messages in the browser.
                I'm not sure I can assist. It does work on Ubuntu but obviously I cannot test on all flavors of Linux.
                Jon
                  I forgot to ask if you can display test.aspx which comes with HS3. If that does not display then there is an issue with serving ASPX pages on your Linux installation.
                  Jon
                    Jon00:
                    Thanks for the function, providing something that should be standard in HS3. On my Linux server I had to rename the VB script file from 'Jon00EventlistASPX.vben' to 'Jon00EventListASPX.vben'; otherwise the browser screen was completely blank.
                    Is 'Download CSV' supposed to work? In both Jon00EventList and Jon00DeviceList, all I get is a .csv file containing just the header row. It doesn't seem to matter if the event list is filtered or not. Is there something I'm doing wrong?
                    BBB
                      How about just
                      http://<ip of homeseer>/JSON?request=getevents
                        Originally posted by BigBadBuzz View Post
                        Jon00:
                        BBB
                        It looks like a bug when used with Linux. I'll correct it tomorrow.
                        Jon
                          I think you're looking for an event's ref id. If so you can get it by creating an event.
                          set it to run manually
                          run a script or script command
                          check the box for 'execute immediate script command'
                          the command to run is:
                          hs.WriteLog("Event Ref ID:", hs.GetEventRefByName("your event's name"))
                          run the event and then check your log.
                            Jon00:
                            BBB
                            Both have now been updated and CSV downloads should now work on Linux builds.
                            Jon
                              Jon:
                              They do both work now! Thanks for the quick fix!
                              Paul
