I have a recurring problem where HS3 crashes every few days. The event viewer shows:
Description:
Faulting application name: HS3.exe, version: 3.0.0.297, time stamp: 0x57c733ef
Faulting module name: ntdll.dll, version: 10.0.14393.206, time stamp: 0x57dacde1
Exception code: 0xc0000374
Fault offset: 0x000d9841
Faulting process id: 0x1c08
Faulting application start time: 0x01d22e5a3709ff4d
Faulting application path: C:\Program Files (x86)\HomeSeer HS3\HS3.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: 417fc19c-0ad6-4a84-8098-3ee0ed282220
Faulting package full name:
Faulting package-relative application ID:
Based on what I see on the interwebs, HS3 is crashing when it asks ntdll.dll to do something it can't do. The Exception code suggests a "heap memory" corruption or problem, apparently caused by an unspecified application.
I'm running HS3 (.297) on Windows 10 Pro (version 1607), plugins are latest of BLAB8SS, BLBackup, Blue Iris, Easy Trigger, HSTouch Server, Open Sprinkler, Sonos, UltraM1G, Ultra1Wire, Weather XML and ZWave. I use Chrome as my browser. No other software runs on this PC. My gut tells me this crash problem started after an update of one of the above (Windows, HS3, Chrome or a plugin).
I do see that my memory can run at 45-50% of 8 GB (much of it Chrome), but it is always HS3 that crashes (followed by Open Sprinkler and HSTouch, but I assume that is because HS crashed first).
Any thoughts or ideas how to fix this?
Description:
