Scripting help please - Run Time errors, Invalid Character at line x
    Hello,
    I am hoping someone can help me, and stop me going mad!
    I can find no way to do this with normal events, so assume it needs to be a script? Any help would be greatly appreciated.
    Philip
    Example of a Test I was doing:
    Sub Main()
    Dim DevRef
    DevRef = hs.GetDeviceRefByName("Hall Lamp")
    if hs.ison(DevRef) then
    hs.writelog("test", "Weather Test Script")
    End If
    End Sub
    This then errors with "Invalid character in line 2". Urghhhh!
    Hi Philip;
    PHP Code:
    Sub Main(byVal parms as Object)
    Dim DevRef As Integer
        DevRef
        if
    hs.ison(DevRefthen
            hs
    .writelog("test""Weather Test Script")
        else
    hs.writelog("test","Light is off")
    End If
    End Sub
    Hope this helps a bit....
    Don
      Is your file suffix .vb ?
      tenholde
      Originally posted by vaugrat View Post
      Hello,
      Philip
      Sub Main()
      Dim DevRef
      End If
      End Sub
      tenholde
        The extension of the file is .txt (although I did try with .vb).....and that threw up a whole host of other errors!
          The example I suggested works for me. Sorry I couldn't be more help. :-(
          Don
            This works for me as a vbscript file (.txt):
            Sub Main()
            Dim DevRef
            DevRef = hs.GetDeviceRefByName("Ensuite Lights")
            hs.writelog "test", "123"
            End If
            End Sub
            You were mixing vbscript and vb.net syntax. I would stick with vb.net and use the example that Don provided.
            Cheers
            Al
              Originally posted by donstephens View Post
              Hi Philip;
              PHP Code:
                  DevRef
                  if
              hs.ison(DevRefthen
                      hs
                  else
              End If
              End Sub
              Thanks Don. I have got your sample to work without error...so I will have a go at recrafting and see if I can modify it to do what I am trying to achieve!
                Great. Please feel free to post if you encounter problems.
                Don
