Why Doesn't this Counter Work?
    I have set up a counter in a simple sprinkler event to give me easy control over the frequency of irrigation. The event looks like this:
    IF Time: 6:00 AM
    AND IF: Sprinkler Program has a value equal to Regular Program Enabled
    AND IF: Sprinkler Interval value has become this or a multiple of this: 3
    THEN: Set Device Sprinkler System Status to Run Regular Program
    However, the event will not trigger the sprinkler when all the conditions are met. However, if I remove the counter condition, it triggers everyday at 6:00 AM. Any idea what's wrong?
    HS4Pro on Windows 10
    One install with 2 Ethernet Z-nets
    2nd install with 1 Ethernet Z-net
    300 devices, 250 events, 8 scripts
    6 CT-100 tstats
    Serial IT-100 interface to DSC Panel with 8 wired zones
    18 Fortrezz water sensors & two valve controls
    Are you using the device created for the counter in the event, or the counter itself? From what I understand, the devices created by counters and timers are there for display purposes, but can't be used for triggers or conditions.
    Cheers
    Al
      Hi Al, I selected the Counter option, not the Device option, in the statement.
      6 CT-100 tstats
        I actually posted the event as I have re-entered it, with the Time statement first; I previously had the Counter statement first. It worked in a test; lets see if it works at the scheduled time.
        6 CT-100 tstats
          That was probably it. If you had the counter first as a trigger, it would have had to change to 3 at exactly 6:00AM. It would be virtually impossible to have both happen at exactly the same time.
          Randy Prade
          Aurora, CO
          Prades.net
            Solved!
            Yep, that was it. Thanks for the help.
            6 CT-100 tstats
              Sprinklers? In winter? Wouldn't have counters or anything.
              Just kidding. Turned off our sprinklers about a month ago.
              Michael
              Michael
                South Texas...we're still growing things.
                6 CT-100 tstats
