HS Speaker Pop Up Too Small
  • HS Speaker Pop Up Too Small
    Hi everyone,
    Spent a couple bucks in parts to piece together a new to me HS machine.
    I'm running the new box with Windows 10.
    I installed HS3 on it and when I went to run the HS Speaker app to connect to my old HS machine just to test it, HS Speaker won't connect because the ports and such are not directed to the HS box downstairs. (It wants to connect locally which I know is normal)
    When I open the dialog box in HS Speaker to configure the settings the pop up box is tiny and I am unable to see the individual boxes to make the needed changes.
    I was looking for some insight as to what's going on with HS speaker before I put it to work running the house.
    Can you post a pic?
    -Rupp
      Hi Rupp,
      I grabbed a screen cap of HS Speaker.
      Thanks for the assistance,
      Dan
        Can you grab the corners and pull it out?
        -Rupp
          No. I did try that again just to be sure I wasn't crazy.
          I'm upgrading from Windows 10 to Windows 7 as I type.
          I will report back.
            I will report back.
            If this doesn't work please report this at support@homeseer.com
            -Rupp
              Go into windows display settings and change text size to 100%. It looks like it is ~200%. You will need to logoff or reboot after.
              Sent from my SAMSUNG-SM-G890A using Tapatalk
                My 2 cents,
                I have exactly the same problem, same window. I backed up from win10 to win7 to see if that would a difference, it didn't.
                Checked the text size, it was 100%.
                I posted a couple posts lower for help on the speech speed. I figured since the window was unaccessible there might be a different way to control the TTS speed.
                I tried adjusting the speed in the OS, that didn't change HS3 speech speed.
                Running v3.0.0.298, win 7 pro, x64
                Paul
                  For anyone reading this, I sent a request in to HS, was told they are working on it.
                  In the mean time, the easy fix was to install the stand-alone HS Speaker app that you can grab on their downloads page.
                    Thanks Dan-O the HS3 speaker download worked for me as well
                    It was annoying having "that lady", as my wife calls her, speak so fast.
                    Question, Do you run both speakers concurrently?,or manually shut down one & start the other?
                    Paul
                    Never mind, I see the download replaces the other version.
