In my log, I sometimes see that my desktop computer has been "blocked from further access to the system". I suspect it's because I have a service running (called Simon) that periodically tests my various servers to make sure they are up. Can someone explain the options on the HomeSeer Tools panel:
Enable IP hack blocking - what precisely does this do (and under what conditions does it block)
Time between hits to count toward block - I don't understand, is this the time that, if you get accesses within that time period, it gets blocked? Mine is set for 10 seconds, which is way shorter than my polling interval from Simon.
