Device label changes aren't saving across reboots
  • Device label changes aren't saving across reboots
    So, I have a door sensor with labels of On-Open-Motion/Off-Closed-No Motion. I change the labels to Open/Closed, but when I reboot my Zee S2 the values revert to the old. As well, after a reboot it doesn't remember the last time a sensor changed value, but will instead remember that the sensor changed a day ago, or several days ago, depending on when the last config update was run.
    How do I force the database/config files to update? I'd like to change some labels and the icons. Thanks.
    zee s2. Plugins: hstouch 103, zwave 96, latest weatherxml and airplayspeak
    Unfortunately I see similar sometimes (majority of reboots it saves) and it must be an issue with the Z-Wave plugin, I would say I see it every couple of months and I see it with my temperature sensors (if I add a degree symbol to the suffix) and also my door sensors if I change the open/close pairs.
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
      This is happening on every reboot for me since Saturday at least. It's become quite the nuisance. Any ideas? Seems my config file is corrupt or something. Can I delete it, would that force that it be re-written?
      How does one make the Data/hsd files update. Mine are all stale. They remember when I change device names, new devices, but existing device label updates do NOT get saved, always stale.
        It's a bit of a workaround, but try running an event like this:
        Cheers
        Al
        HS 3.0.0.548: 1976 Devices 1156 Events
        Z-Wave 3.0.1.262: 123 Nodes on one Z-Net
          [ATTACH]58192[/ATTACH]
          Cheers
          Al
          This has fixed this issue for me since I saw it posted last week. If you have to rescan a device, though, you may lose your custom icons and settings. Not sure why exactly as it doesn't seem to happen every time.
            AMAZING!!! TYTYTYTY
              I don't have this problem anymore but I will add the event
                Man. I thought it was just me. I have noticed this more with my aeon multi sensors removing the degree symbol and the decimal places. Thanks for the event Al. I'd open a bugzilla but...
