HS3 Linux RPi3 Phantom Events
  • HS3 Linux RPi3 Phantom Events
    Dec-27 00:38:07
    Load Config Loading Events...
    I had to update from my HS3 RPi2 because the sd card was getting flaky. I went to a Raspbian Jessie RPi3 running from hard disk instead of the sd card. I first moved the HS3 directory over to the new Pi, which mostly worked but the events were gone and my Honeywell WiFi thermostats wouldn't connect.
    Even though it didn't transfer the events, I have some of them showing up as phantom errors in the log.
    This is the system clip:
    Current Date/Time: 12/27/2016 12:52:46 AM
    HomeSeer Version: HS3 Standard Edition 3.0.0.297
    Linux version: Linux HS4.4.38-v7+ #938 SMP Thu Dec 15 15:22:21 GMT 2016 armv7l GNU/Linux System Uptime: 0 Days 0 Hours 14 Minutes 39 Seconds
    IP Address: 192.168.1.102
    Number of Devices: 221
    Number of Events: 15
    Available Threads: 398
    Enabled Plug-Ins
    3.2.0.5: APCUPSD
    3.1.13.6: CONCORD
    1.1.3.0: Honeywell WiFi Thermostat
    3.0.0.68: HSTouch Server
    3.0.0.58: weatherXML
    3.0.0.36: X10
    3.0.1.87: Z-Wave
    This is the clip of the log with phantom events.
    Dec-27 00:38:07 Warning Unable to load event group, name: Away Dec-27 00:38:07 Error DeSerializing object (byte): Could not find type 'System.Collections.SortedList+KeyList'. Source=mscorlib Dec-27 00:38:07 Warning Unable to load event group, name: Turn down Thermostat when AWAY Dec-27 00:38:07 Error DeSerializing object (byte): Could not find type 'System.Collections.SortedList+KeyList'. Source=mscorlib Dec-27 00:38:07 Warning Unable to load event group, name: Power Dec-27 00:38:07 Error DeSerializing object (byte): Could not find type 'System.Collections.SortedList+KeyList'. Source=mscorlib Dec-27 00:38:07 Warning Unable to load event group, name: Backup Power Dec-27 00:38:07 Error DeSerializing object (byte): Could not find type 'System.Collections.SortedList+KeyList'. Source=mscorlib Dec-27 00:38:07 Warning Unable to load event group, name: Lighting Dec-27 00:38:07 Error DeSerializing object (byte): Could not find type 'System.Collections.SortedList+KeyList'. Source=mscorlib Dec-27 00:38:07 Warning Unable to load event group, name: Christmas Dec-27 00:38:07 Error DeSerializing object (byte): Could not find type 'System.Collections.SortedList+KeyList'. Source=mscorlib Dec-27 00:38:07 Warning Unable to load event group, name: Vacation Dec-27 00:38:07 Error DeSerializing object (byte): Could not find type 'System.Collections.SortedList+KeyList'. Source=mscorlib Dec-27 00:38:07 Warning Unable to load event group, name: Weather Dec-27 00:38:07 Error DeSerializing object (byte): Could not find type 'System.Collections.SortedList+KeyList'. Source=mscorlib Dec-27 00:38:07 Load Config Loading Event Groups...
    How do I get rid of these errors?
    Steve
