Receiving IR with HS3
Get a USBUIRT. Use the BLUSBUIRT plugin to trigger X10 commands based on received IR codes.
Steve Q
Sent from my iPad using TapatalkHomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
Steve Q,
The HS machine is not located nearby to the source of the IR, so based on what I understand this solution may not be for me. However, I wonder how well this thing works as a self-powered extender and then it might be good.
https://goo.gl/Sd1J2r
Thanks.
-r-Rick
I don't know how far you could extend the USB cable, you could try.
You could also try a Powermid to wirelessly extend the IR signal to your HS computer.
https://www.x10.com/pm5900.html
Steve Q
Originally posted by Steve Q View PostI don't know how far you could extend the USB cable, you could try.
Steve Q
Sent from my XT1585 using Tapatalk
