I read other places that users have made this lock work well. But I am not having luck. I have added and removed it several times. I am using the RPi and wondering if that is an issue?
I cant get the RPi closer to the door but every other ZWave added OK
Here is the log. Node 14 is the newly added device.
Mar-24 14:54:36 Z-Wave New Interface2: Sending to node 14 (UnSecured) CC=COMMAND_CLASS_FIRMWARE_UPDATE_MD_V3 Mar-24 14:54:32 Z-Wave New Interface2: Sending to node 14 (UnSecured) CC=COMMAND_CLASS_NO_OPERATION Mar-24 14:54:27 Z-Wave New Interface2: Sending to node 14 (UnSecured) CC=COMMAND_CLASS_FIRMWARE_UPDATE_MD_V3 Mar-24 14:54:14 Z-Wave New Interface2: Sending to node 14 (UnSecured) CC=COMMAND_CLASS_FIRMWARE_UPDATE_MD_V3 Mar-24 14:53:42 Z-Wave New Interface2: Sending to node 14 (UnSecured) CC=COMMAND_CLASS_FIRMWARE_UPDATE_MD_V3 Mar-24 14:52:14 Z-Wave Enabling Lock and System status for Schlage device Node 14 Z-Wave IR Security Safety Entry Control (14) Mar-24 14:52:14 Z-Wave Error Security class information is NOT present - cannot continue loading node 14 Mar-24 14:52:14 Z-Wave Warning Error getting version information for node 14, Send failed. Mar-24 14:52:11 Z-Wave New Interface2: Sending to node 14 (Undefined) CC=COMMAND_CLASS_SECURITY Mar-24 14:52:11 Z-Wave New Interface2: Sending to node 14 (Secure) CC=COMMAND_CLASS_VERSION_V2 Mar-24 14:52:07 Z-Wave New Interface2: Sending to node 14 (Undefined) CC=COMMAND_CLASS_SECURITY Mar-24 14:52:07 Z-Wave New Interface2: Sending to node 14 (Secure) CC=COMMAND_CLASS_SECURITY Mar-24 14:52:07 Z-Wave Getting SECURITY class information for node 14 Mar-24 14:52:07 Z-Wave Warning In case the device was previously added successfully, an attempt will be made to continue the import. Mar-24 14:52:07 Z-Wave Warning If this device was previously added to the network, the device may need to be removed from the network and re-added. Mar-24 14:52:07 Z-Wave Warning The security device may have a timeout when adding to the network, bring the device close to HomeSeer and use the Add Node button to add it (remove it first) Mar-24 14:52:07 Z-Wave Warning Failed to get a SECURITY SCHEME or verify the key from node 14. Device may not be added properly to HomeSeer. Mar-24 14:51:57 Z-Wave New Interface2: Sending to node 14 (Undefined) CC=COMMAND_CLASS_SECURITY Mar-24 14:51:57 Z-Wave ApplicationCommandHandler from node 14 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=64 Mar-24 14:51:57 Z-Wave ApplicationCommandHandler from node 14 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=128 Mar-24 14:51:57 Z-Wave New Interface2: Sending to node 14 (Undefined) CC=COMMAND_CLASS_SECURITY Mar-24 14:51:57 Z-Wave ApplicationCommandHandler from node 14 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=5 Mar-24 14:51:57 Z-Wave New Interface2: Sending to node 14 (UnSecured) CC=COMMAND_CLASS_SECURITY Mar-24 14:51:57 Z-Wave Negotiating or Verifying SECURITY SCHEME for node 14 Mar-24 14:51:57 Z-Wave Z-Wave manufacturer information for node 14, ID: 59=3BH (IR Security Safety), Type: 25409=6341H, ID: 20548=5044H Mar-24 14:51:57 Z-Wave ApplicationCommandHandler from node 14 HANDLING: COMMAND_CLASS_MANUFACTURER_SPECIFIC Frame(7)=5 Mar-24 14:51:57 Z-Wave New Interface2: Sending to node 14 (UnSecured) CC=COMMAND_CLASS_MANUFACTURER_SPECIFIC Mar-24 14:51:57 Z-Wave Synchronize nodes finished. Number of device nodes to be created/added = 1 Mar-24 14:51:56 Z-Wave ApplicationCommandHandler from node 14 HANDLING: COMMAND_CLASS_MANUFACTURER_SPECIFIC Frame(7)=5 Mar-24 14:51:55 Z-Wave New Interface2: Sending to node 14 (UnSecured) CC=COMMAND_CLASS_MANUFACTURER_SPECIFIC Mar-24 14:51:55 Z-Wave Done. Node 14 Added.
