Where can I get basic info on HS for Raspberry Pi?
    The HS website literally has a one-pager for install HS onto a Pi and no other data. I'd like to use the Pi running as a DIO unit in conjunction with my main HS. So questions:
    1) How do I access the DIO pins of the Pi? Are these already installed as "Devices"?
    2) Can I assume that Devices are the same as a PC version as are Events?
    3) I have to imagine that logging is limited since there is limited storage ... how does that work?
    4) Is the Pi HS run a webserver like it's big brother?
    5) If #4 is yes, does JSON (misnamed) calls work?
    6) Can I do an outbound REST call from the Pi? (Today I can do as a VBScript, for example.)
    Thanks. Any pointers would be helpful!
