Try rebooting, connect the Ethernet, and see an IP address gets assigned.
Starting with Raspberry
OK, I've recreated your issue.
Upon bootup, on the console appears a prompt "Enter r then press ENTER within 10 seconds to reset the network settings"
Doing this will disable Ethernet !!!
To fix:
sudo rm /etc/network/interfaces
To prevent it happening ever again
sudo rm /var/www/Main/interfaces_default
HomeSeer really needs to update their Linux scripting - the stuff that worked two OS releases ago doesn't necessarily work forever!!
- 1 like
Great!
Some more info, for anyone interested...
The file content shown in post #51 photo is from /var/www/Main/interfaces_default. This file is copied to /etc/network/interfaces when R+Enter is entered at bootup. [ The script that does this is located at /var/www/Main/checkkb, called from /etc/rc.local ]. This is not a valid interfaces file for the OS version of the HS3Pi3v5. With this in place, wireless LAN works, but wired LAN is disabled.
For the current OS, the /etc/network/interfaces file isn't required if a "basic" connection is all that's required. So removing the file altogether was used in this case to get things back on track.
