HS in caravan
    #16
    Originally posted by sparkman View Post
    Because the Pi does not have an analog input, you would need to use a voltage divider circuit and then an analog to digital converter. There are some example projects like that on the internet, so not too difficult (if you're comfortable with electronics). Here's one example I found: http://www.lediouris.net/RaspberryPI...nitor-12v.html
    I have achieved, through the analog inputs of a Fibaro RGBW module and a voltage divider, a reading of 11.2v to 13.4v.
      #17
      Great!
        #18
        This has been on hold for a while ..., I have resumed again ..., basically it is a hoby and when there are more important things ...
        Started designing PCB for RPi IN / OUT ...
        Voltage sensor results are acceptable, I can measure between 11v to 15v with 0.2-0.4v precision. For an auxiliary battery it can be used.
        Right now I think about how powered RPi, I am going to try connecting to the auxiliary battery through a StepDown voltage module. Although I don't know if another smaller battery or a UPS system would be better.
