Help. With aspx on Home Troller Raspberry PI
    I am trying to run aspx on homeseer . I have read some of the forum posts on this issue but a litlle confused with RP Linux. I have the following version of Mono installed:
    4.5.1. My current version of homeseer is : HS3 ZEE S2 Edition 3.0.0.548
    I tried to locate VBNC and its not installed. I tried installing it but it failed due to broken components. I tried updating mono it also falied. Could someone point me in the right direction?
    Will
    Try https://helpdesk.homeseer.com/articl...date-to-mono-5
    If that doesn't work, yell...
      Thank you . I have installed the updated version of Mono. I get the following error when executing:
      <%@ LANGUAGE="VBSCRIPT"%>
      <html>
      <head>
      <title>Hello World</title> </head>
      <body bgcolor="White">
      <div align="center"><h1>Hello World</h1></div>
      <br><p><hr><p>
      <%Response.Write("Hello World!")%>
      </body>
      </html>
      System.SystemException
      Error running vbnc: Cannot find the specified file
      Description: HTTP 500.Error processing request.
      Details: Non-web exception. Exception origin (name of application or object): System.
      Exception stack trace:
      at Microsoft.VisualBasic.VBCodeGenerator.FromFileBatch (System.CodeDom.Compiler.CompilerParameters options, System.String[] fileNames) [0x000eb] in <f74b9f2fea8d47a7922726600e468191>:0 at System.CodeDom.Compiler.CodeCompiler.System.CodeDom.Compiler .ICodeCompiler.CompileAssemblyFromFileBatch (System.CodeDom.Compiler.CompilerParameters options, System.String[] fileNames) [0x0003a] in <f74b9f2fea8d47a7922726600e468191>:0 at System.CodeDom.Compiler.CodeDomProvider.CompileAssemblyFromF ile (System.CodeDom.Compiler.CompilerParameters options, System.String[] fileNames) [0x00006] in <f74b9f2fea8d47a7922726600e468191>:0 at System.Web.Compilation.AssemblyBuilder.BuildAssembly (System.Web.VirtualPath virtualPath, System.CodeDom.Compiler.CompilerParameters options) [0x0029f] in <51af09eb4cc84340898f1133a5df1f38>:0 at System.Web.Compilation.AssemblyBuilder.BuildAssembly (System.Web.VirtualPath virtualPath) [0x00008] in <51af09eb4cc84340898f1133a5df1f38>:0 at System.Web.Compilation.BuildManager.GenerateAssembly (System.Web.Compilation.AssemblyBuilder abuilder, System.Web.Compilation.BuildProviderGroup group, System.Web.VirtualPath vp, System.Boolean debug) [0x00202] in <51af09eb4cc84340898f1133a5df1f38>:0 at System.Web.Compilation.BuildManager.BuildInner (System.Web.VirtualPath vp, System.Boolean debug) [0x00106] in <51af09eb4cc84340898f1133a5df1f38>:0 at System.Web.Compilation.BuildManager.Build (System.Web.VirtualPath vp) [0x00058] in <51af09eb4cc84340898f1133a5df1f38>:0 at System.Web.Compilation.BuildManager.GetCompiledType (System.Web.VirtualPath virtualPath) [0x00037] in <51af09eb4cc84340898f1133a5df1f38>:0 at System.Web.Compilation.BuildManager.GetCompiledType (System.String virtualPath) [0x00006] in <51af09eb4cc84340898f1133a5df1f38>:0 at System.Web.HttpApplicationFactory.InitType (System.Web.HttpContext context) [0x0020f] in <51af09eb4cc84340898f1133a5df1f38>:0 at System.Web.HttpApplicationFactory.GetApplication (System.Web.HttpContext context) [0x00018] in <51af09eb4cc84340898f1133a5df1f38>:0 at System.Web.HttpRuntime.Process (System.Web.HttpWorkerRequest req) [0x00052] in <51af09eb4cc84340898f1133a5df1f38>:0
        My impression is that vbscript isn't supported on Linux.
        Do you have a file named test.aspx in /usr/local/HomeSeer/html/ ? This is included in fresh installs, but it doesn't appear to be included in the incremental archive used when updating.
        If its there, open http://<hs3 ip address>/test.aspx in your browser.
        For this to work, you'll need to add the "aspx workaround" discovered by an enterprising forum member, bsobel. We'll get to that presently; in the meantime, run these commands at the Linux command line and post the output.
        dpkg -V mono-vbnc
        type vbnc
        file /usr/bin/vbnc
        If there's no output from the 1st one - that's good.
        The 2nd one should output "vbnc is /usr/bin/vbnc"
        If the 2nd is correct, the 3rd one will output either "/usr/bin/vbnc: Bourne-Again shell script, ASCII text executable" or "/usr/bin/vbnc: POSIX shell script, ASCII text executable" depending on whether or not you have the above mentioned workaround in place.
          Thanks again for the quick reply.
            I went ahead and installed vbnc
            result is as you expected
Name:	Annotation 2019-09-23 024058.jpg
            Now error has changed
            also I dont have the test.aspx that came with fresh install, anywhere to download it? Thanks
            Will
              OK, now you have the "expected" error!!
              What you need to do is to replace the contents of /usr/bin/vbnc with the following:
              #!/bin/bash
              # mono vbnc invocation script patched for HS3 aspx compatability
              for x
              do
                  if [[ $x =~ ^/tmp/ && -e $x ]]
                  then
                      sed -i '1{/#External/d}' $x
                  fi
              done
              exec /usr/bin/mono --debug $MONO_OPTIONS /usr/lib/mono/4.5/vbnc.exe "$@"
              test.aspx is included in the "full" installer, found at https://homeseer.com/updates3/hs3pi3_070319.tar.gz I doubt that anyone will kill me for posting it here...
              <%@ Page Language="VB" %>
              <script runat="server">
                  ' Insert page code here
                  Dim hs As Scheduler.hsapplication
                  Dim plugin As HomeSeerAPI.PluginAccess
                  Sub Page_Load(Sender As Object, E As EventArgs)
                      ' for use with the HS web server
                      hs = Context.Items("Content")
                      ' get a reference to the Z-Wave plugin
                      plugin = New HomeSeerAPI.PluginAccess(hs, "Z-Wave", "")
                      If plugin.Connected Then
                          Label2.Text = "Connected to Z-Wave plugin, name=" & plugin.Name
                      End If
                      label1.text = "HomeSeer Ver: " & hs.version
                              Dim EN As Scheduler.Classes.clsDeviceEnumeration
                              Dim dv As Scheduler.Classes.DeviceClass
                      EN = hs.GetDeviceEnumerator
                              Do
                          dv = EN.GetNext
                          If dv Is Nothing Then Continue Do
                      Loop Until EN.Finished
                  end sub
                  Sub ButSpeak_Click(sender As Object, e As EventArgs)
                      hs.speak(txtspeak.text,false,"")
                              Do
                          dv = EN.GetNext
                              '       hs.WriteLog("SAMPLE", "Found device from aspx: " & dv.Name(Nothing))
                      '    If dv.Interface(Nothing) IsNot Nothing Then
                       '       If dv.Interface(Nothing).Trim = "Sample Plugin" Then
                      '        End If
                      '    End If
                  End Sub
                  Protected Sub Button1_Click(ByVal sender As Object, ByVal e As System.EventArgs)
                      'hs.ExecX10("q7", "on")
                  End Sub
                  Protected Sub Button2_Click(ByVal sender As Object, ByVal e As System.EventArgs)
                      'hs.ExecX10("q7", "off")
                  End Sub
                      Private Function GetHeadContent() As String
                      Try
                          Return hs.GetPageHeader("", "Test Page", "", "", False, False, True, False, False)
                      Catch ex As Exception
                      End Try
                      Return ""
                  End Function
                      Private Function GetBodyContent() As String
                      Try
                          Return hs.GetPageHeader("", "Test Page", "", "", False, True, False, True, False)
                      End Try
                      Return ""
                  End Function
              </script>
              <html>
              <head runat="server">
              <%response.write(GetHeadContent())%>
              </head>
              <body>
              <% response.write(GetBodyContent()) %>
                  <form runat="server">
                      <p>
                          <asp:Label id="Label1" runat="server" width="210px">Label</asp:Label>
                      </p>
                      <p>
                          <asp:Label id="Label2" runat="server" width="400px">Label</asp:Label>
                      </p>
                      <p>
                      </p>
                      <p>
                          <asp:Button id="ButSpeak" onclick="ButSpeak_Click" runat="server" Text="Speak"></asp:Button>
                          <asp:TextBox id="TxtSpeak" runat="server"></asp:TextBox>
                      </p>
                      <p>
                          <asp:Button ID="Button1" runat="server" OnClick="Button1_Click" Text="Light On" />
                      </p>
                      <p>
                          <asp:Button ID="Button2" runat="server" OnClick="Button2_Click" Text="Light Off" />&nbsp;</p>
                      <!-- Insert content here -->
                  </form>
              </body>
              </html>
                Thank you.
                Ok I tried replacing the file vbnc through winscp , but file permissions are denied. I suspect I have to do this as root, but I dont have the password. Any thoughts
                I also tried nano , permisison also denied
                  Both homeseer and pi should be set up as sudo users. To use that, preface the command with sudo, i.e.
                  sudo nano /usr/bin/vbnc
                    Thanks agian. I was able to edit the file. Now getting following error on execution of test.aspx:
Name:	last error.JPG
                    I am open to learning a new language. What do most people use with the RP Deployment?
                    Will
                      To use VB.NET, use this instead:
                      HS 4.2.8.0: 2134 Devices 1252 Events
                      Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
                        my bad I executed the wrong file. Dah! Thanks
                          Thank you all . I am up and running with aspx and vb script
