I have hs3 version 3.0.0.313 and i want to upgrade to 3.0.0.500 anyone know will this be easy process ...any steps?
upgrade homeseer
Originally posted by sk74991 View PostI have hs3 version 3.0.0.313 and i want to upgrade to 3.0.0.500 anyone know will this be easy process ...any steps?
Reboot the server. Wait for a while, if everything is settled down enable HSSentry in settings.
Eman.TinkerLand : Life's Choices,"No One Size Fits All"
Originally posted by sk74991 View Postim running this on linux raspberry pi. Do i need to download and extract tar file and do upgrade or can i do this via a gui somehow?
Note : Make sure you change the version number before you execute the command.
If you’re running on a Raspberry Pi take an image of your SD card as a backup before you update. If anything goes wrong you can just write that image back to your SD card.
Stop the Homeseer service first. Just wget the version of HS you want and tar it to the SD card. Start the Homeseer service when you finish and you should be good to go.
I forgot to mention that if you running home brew Linux/R PI download this sweet tool : https://mobaxterm.mobatek.net/ Then drag and drop the file in the (PI) home folder. Stop HomeSeer first! then execute the command. And sudo reboot .
Note : The whole operation assumes that you have your HomeSeer in the "/opt" folder. If not then change.
