(Posted this initially in the HS3/Pro subforum, inadvertently.)
Starting yesterday I began to see continuous errors (every 2-3 seconds or so) in the HS3 log. The error messages come in this pair:
Error Authenticating SSL stream inner exception: Authentication failed, see inner exception
Error Authenticating SSL stream: One or more errors occurred. (Authentication failed, see inner exception.)
Any suggestions on what I should check? The unfortunate by-product is that eventually HS3 crumbles and I can't even reach the GUI; I need to reboot to bring it back to life.
I'm running HS3 on a Raspberry Pi. The only plugin is X10. Things appeared to be working fine for the first 2 months.
