Ok, I've read posts on earlier HS3 having issue(s) on static IP entries, but thought this was resolved (I think posts were from 2015/6).
Currently using:
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.548
Linux version: Linux HomeTrollerZeeS2V6 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
Interface fairly strait forward on assigning static IP's; the LAN interface appears w/o issue, working as intended.
However on WLAN interface, not able to obtain an IP unless I create a reservation on the router (DD-WRT).
Was curious if this normal? Including several printers, scanners, cameras, & other devices on the home LAN, don't remember having to create reservations for other devices (not that I can think of).
Thanks, Jeff
Currently using:
Thanks, Jeff
