Pi Volume
    Pi Volume
    How do I set the Pi output volume, It seems it set at about 50% want to change it to %90
    Or can you set the output volume when an event is play a wav file ?
    Change Volume Output
    By default the output audio on the Zee S2 and Pi3 image is low. This can be changed via Linux tools, using SSH to connect to the unit, or using a monitor and keyboard.
    Use the following command to set the volume to max
    sudo amixer set PCM -- 100%
