new V3 pro on pi, with existing license, no plugins
    i tried to upgrade to V4, cant get anything to work.. need to get back online..
    install legacy v3, new sd card.. ok, running, time for devices.. oops.. no plugins under plugins/manage, says it updated the list, but the ssection is not expandable..
    need to re-setup the Sandler Insteon module
    is this because I used my V4 license to say I upgraded?
      Does your HS3 show as being licensed on the HS3 GUI?
      -Rupp
        yes
        License
        System Licensed as HS3 ZEE S2 (LicenseID=xxyyzz)
        Current version is: HS3 ZEE S2 Edition 3.0.0.551
          It sounds like you may not have web access if no plugins are loading. What happens if you select Plugins > Manage > Update Listing?
          -Rupp
            the bar above the button shows progress, and then says completed,,,
            suddenly after a day, the plugin dropdown is there.. yeesh..
              sat overnight, and all this morning, tried all kinds of things rebooted, restarted HS.. ethernet wire attached
                all working now... don't know what the holdup was.
