Device Ref:
    Device Ref:
    What do the numeric numbers after Device Ref: in the warning messages below refer to? How do I track devices these down?
    Click image for larger version  Name:	Screenshot 2022-10-26 223958.jpg Views:	0 Size:	58.2 KB ID:	1572808
    Malcolm
    They are the unique device reference for each virtual device on your system.
    Not easy to see in HS3 but are defined in the advanced tab as shown below.
    Click image for larger version  Name:	Capture.png Views:	0 Size:	18.5 KB ID:	1572812
    The devices shown are not the cause of the issue but have been dropped from processing due to the process queue buffer exceeding the limit of 2000 entries.
    If this has just started, have you updated/added any plugins recently?
    Jon
      Thanks. That's helpful. It's happens most nights around 10pm. Need to try and find what's filling the queue. An event maybe...
      Malcolm
        Is there any way to view the process queue buffer in HS3?
        Malcolm
          Yes, from Tools > Control Panel/Run Immediate script command enter:
          &hs.debugmode=2
          You will see the entries in the HS Log (lots of them!)
          To stop use:
          &hs.debugmode=0
          Jon
            Thanks Jon. I've applied that (&hs.debugmode=2​) and I was kinda expecting to see the log fill up with lots of messages but other than the occasional zwave warning messages that I've not noticed before there's nothing else. Any thoughts?
            Malcolm
              I get lots of debug messages but my system is rather busy.
              You should see "EVENT DEBUG" log messages under the Type/Error column if the debug command was active.
              Jon
