Introducing HS3-Pi
    #46
    Hometroller Zee2 vs HS3-Pi vs HS3 Std. Linux
    Hello homeseers,
    Anyone care to clarify how the HS3-Pi downloadable software differ from the software that comes onboard with the Hometroller Zee2?
    AFAIK, on the Hometroller Zee2, you are limited to 5 plug-ins of your choice. Does the same limit apply to a HS3-Pi license? Any other limitations one should be aware off?
    Additionally, can one download the HS3-Pi software, bake a microSD card with it, boot it up to install, then simply replace the Homeseer folder with a Homeseer folder backed up from a previous HS3 Std. Linux install, in order to move a working installation from a Pi2 to newer Pi3 hardware?
    If so, that would simplify the HS3 Linux install process, since you wouldn't need to manually install Debian, Mono and everything else.
    Thanks in advance,
    Cesar
      #47
      The downloadable software is just an image with a boot script to bake your own Zee2.
      The versions of HS3 lite are the same on the two.
      no.
      Yes and no.
      I did that originally with the first Zee2 and just copied out the HS3 directory to my own DIY RPi2 way back.
      A HS3 standard and Pro build will can tax your RPi3/RPi2 if you push it. I am taxing my Zee-2 build right now adding the limit of plugins plus a bunch of scripts.
      Best to try it yourself.
      The image is propietary with a DR recovery mode that will wipe out the running OS HS3 partition and build a new one.
      Yes.
      Yes but you still will need to be aware of the Linux OS a bit. I personally here have kept the Wheezy OS up to date.
      And the contradiction to the above statement.
      There are many Zee-2 folks that have never updated the Wheezy OS and are still running the original un updated OS and HS3 is running fine.
      - Pete
      Auto mator
        #48
        Thanks, Pete. Will start on the new PI3 from scratch. Since I'll have to start from square one, I may even try to put that old Udoo Quad sadly lying on a drawer to some use...
          #49
          There is no breaking of the Pi3 and it seems to me that the newest microSD cards are better made than those of yesteryear.
          I got a warm and fuzzy knowing a bit about a Windows OS / Homeseer same as Linux OS / Homeseer. But that is me.
          That said my old circa 2009 Intel Atom based 7" tabletops (big board embedded Intel stuff) are still running just fine with soldered on good stuff MMC memory and a dash of old and slow SSD. Both are utilized today for one OS.
          Udoo Quad......we now have mini Intel Cedarville, Penwell, Cloverview, Baytrail, Morefield, Cherry Trail and Braswell...where do these names come from anyways?
          Over the years did switch out my USB boot based irrigation controller to a USB / SSD based one. I don't pay attention to it anymore today. It just works and is based on the whole fat ARM CPU / linux / mono thing.
          - Pete
          Auto mator
            #50
            HS3 OR HS3 PI
            Good morning Pete,
            I am looking at switching over to using either the HS3 software to run on a dedicated ACER Rivo desktop with Atom processor, or to go to the Raspberry PI with HS3 PI software.
            I am sure the following have been answered before, so feel free to redirect me to another section of the forum.
            I am looking at switching over to Z-Wave, I have looked at different venues but none seem to meet my simple requirement. I simply want to do be able to control my modules, via conditional If and Then action, but without the INTERNET, for processing.
            Maybe the initial setup could be done via the Internet but once completed, I want to disconnect and have to have my system work on its own, I want commands and action reaction to be instantanious, and not have to go through the Internet and back.
            PS, please note that I'm an old fart with no programming experience or expertise, I don't understand all these API stuff or whatever.
            Thanks Pete
            Dom
              #51
              Welcome to the Homeseer forum Dom!
              Try them both if you want.
              Will you be running Wintel or Linux on the Acer Rivo? Guessing it comes with Windows on it. The RPi off the shelf runs Linux but not windows.
              Here started with the HS3 Zee-2 DIY'd with a Z-Wave GPIO / RTC shim and put it in the attic with a fast microSD card.
              The recently tested(ing) the Pine64/2Gb RPi-like (built in RTC with battery) device running Ubuntu 16.04 64bit and a Xi3/Xi5A AMD based (with a 32Gb mSATA card / 2Gb of RAM) also running Ubuntu 16.04 64bit. Both work fine.
              Left the RPi2 (old seer) in the attic with Z-Wave and remoting the controller to the Xi5A.
              Many folks are using USB Stick Z-Wave controllers which work fine. I have them here too.
              Homeseer 3 (Zee-2 lite), Homeseer 3 Standard and Homeseer 3 Pro all do what you want. I personally have the HS3 INTERNET stuff off and do not utilize it on my Zee-2 (HS3 lite) and HS3 Pro box. It is just a check box in the HS3 GUI.
              It's quick to me but I am old such that quick is relative to my age now.
              It's been mentioned this morning. You can run HS3 on Linux and never do anything with the HS3 provided Linux OS if you wanted to. The Homeseer GUI is the same in Windows and LInux.
              - Pete
              Auto mator
