Gmail problems -Solved!
    I am running RPi HS3 Standard Edition 3.0.0.182 (Linux) and the gmail set up does not work. I get the following error: Exception sending email via GMail (To:jmm@outlook.com, cc:, bcc:, Sub:Front Door, Attach = 5.7.14.
    I do not know what it means. I have tried all of the other tricks in the other posts, but no luck.
    Any help would be appreciated.
    John
    Had the same error.
    To solve go to gmail website and log in with your gmail credentials. Go to settings - Accounts and Import. Click Other Google account settings.
    Under Sign in and Security you should set 'Allow less secure apps' to on. This fixed it for me.
      Thanks, that work. I do not use my gmail account for sensitive issues, so I guess I am not concerned it is not secured.
      John
        Thanks, just came across this problem to and resolved it thanks to this thread :-)
        Simon
          This does not work if you have 2 factor authentication turned on in Gmail.
          See this post:
          https://forums.homeseer.com/showthread.php?p=1211347
            Just made this change as well, but it's hardly a "fix" - it's a serious security problem in Homeseer itself!
              No it’s not. HS talks to smtp servers. Your welcome to run your own. The gmail switch is just a helper to setup the config. The required auth choices are googles decision.
