Linux TTS - Voices
    Linux TTS - Voices
    Hi Guys
    Had a play with HS Touch on a tablet last night, oh dear the TTS voice (Flite) sounds like a Dalek :-)
    Does HS Voices work on Linux ? I had HS2 running with nice voices years ago but that was on Windows.
    Is there a better TTS engine that anyone has got working ?
    I'm loving HS on my Raspberry :-)
    HS 2.2.0.11
    Yeah, the built in tts is quite horrible The Google tts engine was quite good, but they dropped support for real-time tts. I ended up taking my most used announcements and saved them and play as wav files instead of wasting cpu on regenerating then every time.
    Sent from my SCH-R970X using Tapatalk
    68 Z-Wave Nodes, 175 Events, 359 Devices
      How did you end up recording your wav files ? I've had a quick look at google translate and cant seem to get the file...
      Is there a URL thats still active ?
      Thanks..pete
      HS 2.2.0.11
        They've changed it - before, you could get to a playback screen where you right-click and save the mp3 file. Try clicking the 'share' icon and see if you can email it to yourself. Hopefully they havent locked that out
          Share to e-mail, locked out :-)
          HS 2.2.0.11
            Ugh. That stinks. It was a fantastic service
            Sent from my Xoom using Tapatalk
              I converted Raspberry Pi2 deployment of HS3 to Pico using this guide. Not nearly as good as google's, but TREMENDOUSLY better that the default flite TTS. and this is fully offline (not cloud based).
              http://board.homeseer.com/showthread.php?t=173837
                Ahh dlover
                I saw your thread a while ago and couldnt find it again :-(. Thanks for pointing it out, will give this a go..
                Cheers..Pete
                p.s I would so love to have "Allison" back :-)
                HS 2.2.0.11
                  Originally posted by petez69 View Post
                  Hi Guys
                  Can you record "you will be eliminated!" and post?
                  ~Bill
                    Hmm, appears PICO is already installed by default. I might VERY RELUCTANTLY fire up windows on a SFF PC....bah, I dont want to !!!!! I miss Allison...
                    HS 2.2.0.11
                      I know its an old thread, but I got audio files from text here:
                      http://soundoftext.com/
                      and resampled to 44100 for airplayspeak here:
                      http://audio.online-convert.com/convert-to-wav
                      I figured the above is easiest for me given that all my audio is hardcoded and better linux tts voices seem terribly difficult to configure. And even if they aren't compiling from text each time is wasteful, and downloading them on the fly each time is plain stupid.
                        just got TTS working on linux. Can't stop laughing haha.
                        Need to search how to change this voice
                          raspberry pi no sound installed iqaudio board sill no sound, help please
                            If you don't mind a paid option, I just implemented the Polly python script from the forums. Having announcements in the same voice as Alexa is fantastic for those who interact with the system.
                              Stop Homeseer 3.
                              Using terminal check your audio functions first.
                              Once you have validated that your iqaudio board is working then install flite.
                              sudo apt-get install flite.
                              reboot you RPi / Homeseer 3 box.
                              - Pete
                              Auto mator
                              HS4 Pro - V4.1.10.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
                              HS4 Lite -
