I have HS3 (3.0.0.280) setup and running fine on a RPI3 (Raspbian GNU/Linux 8.0 (jessie)) and having trouble getting the Razberry card to be recognised.
It can detect the Razberry GPIO card fine with z-way-server software that came with it. That was installed first to disable bluetooth etc. The z-way-server, sb_connect and mongoose services were disabled afterwards by removing the /etc/init.d/ scripts.
When I try to add it as a z-wave interface the only serial port available is dev/ttyS0, I need dev/ttyAMA0 to appear in the dropdown from what I've found online.
Doing a dmseg | grep tty I get the following (with and without serial login shell set):
In both situations I can still only see ttyS0.
enable_uart=1 was added to the end of /boot/config.txt which I thought may have done it, however HS3 stubbornly refuses to show ttyAMA0.
I tried using ttyS0 just in case but that errors out.
To be honest i've messed around with so many settings other than listed here that a fresh install maybe required and try again.
If anybody can suggest anything it would be great appreciated!
[ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0xfcb402e8 smsc95xx.macaddr=B8:27:EB:B4:02:E8 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 console=ttyAMA0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [ 0.001332] console [tty1] enabled [ 1.818746] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2 [ 2.976915] console [ttyAMA0] enabled [ 3.911204] systemd[1]: Expecting device dev-ttyAMA0.device... [ 4.492334] systemd[1]: Starting system-serial\x2dgetty.slice. [ 4.501095] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0xfcb402e8 smsc95xx.macaddr=B8:27:EB:B4:02:E8 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [ 0.001327] console [tty1] enabled
[ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0xfcb402e8 smsc95xx.macaddr=B8:27:EB:B4:02:E8 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [ 0.001332] console [tty1] enabled [ 1.820067] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
06:30:56:2867:[Z-Wave Warning]->New Interface: Cannot configure COM port /dev/ttyS0, will attempt an open. Error: New Interface: Cannot open COM port /dev/ttyS0, exiting. Ex=Input/output error 06:30:57:4895:[Z-Wave Error]->New Interface: Cannot open COM port /dev/ttyS0, exiting. Ex=Input/output error
