I just moved from windows HS3 to Linux (same Serial ID) on a pi3 and I'm now having trouble using hs.GetURL in my events or writing a .vb script. Other Scripts seem to work but I don't run many.
I'm using "HS3 Standard Edition 3.0.0.297 (Linux)"
I'm trying to control my Roomba and Blueiris Profiles based off home an away and day and night.
Problem is I get an error after switching to linux.
or
depending if I write my on .vb
The Url "http://192.168.1.109/command.json?command=max" Starts the roomba just fine from a web browser and used to work on windows HS3.
I have the same issues when trying to change blueiris profiles
I have tried changing case on the false, chaining to "0" changing ".hs" to ".nhs"
Anyone see an obvious problem or know of a problem behind the scenes (I'm no good with Linux, maybe a program is didn't get installed?) that could cause this problem?
Oct-25 10:10:03 AM Error Compiling script /usr/local/HomeSeer/scripts/BettyClean.vb:
Oct-25 10:10:03 AM Event Running script in background: /usr/local/HomeSeer/scripts/BettyClean.vb
Oct-25 10:10:03 AM Event Event Trigger "Test"
Oct-25 10:10:03 AM Event Event Test triggered by the event page 'Run' button.
Oct-25 9:56:43 AM Error Compiling script /tmp/K13.vb:
Oct-25 9:56:43 AM Info Running immediate script: /tmp/K13.vb
Oct-25 9:56:43 AM Event Running script statement immediately: &hs.GetURL("http://192.168.1.109","/command.json?command=max",True,80)
Oct-25 9:56:43 AM Event Event Trigger "Test"
Oct-25 9:56:43 AM Event Event Test triggered by the event page 'Run' button.
Oct-24 9:04:25 PM Error Compiling script /tmp/K9.vb:
Oct-24 9:04:25 PM Info Running immediate script: /tmp/K9.vb
Oct-24 9:04:25 PM Event Running script statement immediately: &hs.GetURL("192.168.1.100","/admin?profile=1&lock=2&user=XXXXXX&pw=XXXXX",FALSE,9091)
Oct-24 9:04:25 PM Event Event Trigger "BlueIris AwayDay"
Oct-24 9:04:25 PM Event Event BlueIris AwayDay triggered by the event page 'Run' button.
