Open Source Weather Underground PlugIn
  • #16
    Hi TeTTiweTTi,
    Latest version is definitely 0.1.53. Version is not something Plug controls directly, it comes with file. You can verify file version by right click -> Properties of file.
    The xml you provided looks fine as expected. Also you can please confirm that Current Temperature is selected in Configuration Page of Plug In.
    Deepak
    • #17
      hi,
      have now version 1.5.3 installed.
      I have the current temperature selected in the tab "current"of the configuration page of the plugin.
      In fact I have all possible devices selected.
      below the more detailled log
      Jun-10 05:56:26	 	WU Weather	Finished Processing update from station:IWERVIK2
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Wind Speed Address [Current.Wind Speed] to Invalid Value
      Jun-10 05:56:26	 	WU Weather	Debug:Device Wind Speed Address [Current.Wind Speed] has Non-Double Value:[1.0]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Wind Gust Speed Address [Current.Wind Gust Speed] to Invalid Value
      Jun-10 05:56:26	 	WU Weather	Debug:Device Wind Gust Speed Address [Current.Wind Gust Speed] has Non-Double Value:[5.0]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Wind Direction Address [Current.Wind Direction] to [270]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Wind Summary Address [Current.Wind Summary] to [Calm]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Visiblity Address [Current.Visiblity] to Invalid Value
      Jun-10 05:56:26	 	WU Weather	Debug:Device Visiblity Address [Current.Visiblity] has Non-Double Value:[N/A]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating UV Address [Current.UV] to [-1]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Solar Radiation Address [Current.Solar Radiation] to Invalid Value
      Jun-10 05:56:26	 	WU Weather	Debug:Device Solar Radiation Address [Current.Solar Radiation] has Non-Double Value:[]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Pressure Trend Address [Current.Pressure Trend] to [0]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Pressure Address [Current.Pressure] to [1018]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Precipitation Today Address [Current.Precipitation Today] to [0]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Precipitation 1hr Address [Current.Precipitation 1hr] to [0]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Humidity Address [Current.Humidity] to [84]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Feel Like Temperature Address [Current.Feel Like Temperature] to Invalid Value
      Jun-10 05:56:26	 	WU Weather	Debug:Device Feel Like Temperature Address [Current.Feel Like Temperature] has Non-Double Value:[12.3]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Temperature Address [Current.Temperature] to Invalid Value
      Jun-10 05:56:26	 	WU Weather	Debug:Device Temperature Address [Current.Temperature] has Non-Double Value:[12.3]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating DewPoint Address [Current.DewPoint] to [10]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Summary Address [Current.Summary] to [Partly Cloudy]
      Jun-10 05:56:26	 	WU Weather	Debug:Updating Current Address [Current] to [10/06/2017 05:53:03]
      Jun-10 05:56:26	 	WU Weather	Debug:Got valid data from XML Data from http://api.wunderground.com/api/b94178d7b172efab/yesterday/forecast/conditions/alerts/q/pws:IWERVIK2.xml
      Jun-10 05:56:25	 	WU Weather	Debug:Making call to get XML Data from http://api.wunderground.com/api/b94178d7b172efab/yesterday/forecast/conditions/alerts/q/pws:IWERVIK2.xml
      Jun-10 05:56:25	 	WU Weather	Debug:APIKey:b94178d7b172efab Refresh Interval:15 Minutes Station:IWERVIK2
      Jun-10 05:56:25	 	WU Weather	Starting data fetch from WU Weather from station:IWERVIK2
      • #18
        great plugin, thanks...
        any way to include 10 day foecast?
        Thanks, bye
        • #19
          Hi TeTTiweTTi,
          Thanks for providing logs. I think I figured out the problem. I think your computer's locale uses comma as decimal separator. I missed invariant localization enforcement at few places.
          I have fixed that.
          Can you try new build ?
          Deepak
          • #20
            Hi Deepak,
            great thinking. my pc indeed uses a comma. I've updated and this has solved m problem.
            Many thanks.
            TeTTiweTTi
            • #21
              Is it tested on Linux?
              The Readme only says win10.
              • #22
                WU API is no longer
                It appears that WeatherUnderground no longer supports free API keys. See here: https://www.wunderground.com/weather/api/ anyone know a workaround for this? I was troubleshooting why my temperature was stuck at 6 degrees when it is 70 out.
                • #23
                  Will this work with a ZS2?
                  • #24
                    Not sure but it should work as it is Windows 10.
                    • #25
                      My Free WU Key is still working without problem.
                      • #26
                        +1
                        Jean-Francois.
