Important if you are using the Newtonsoft DLL in your plugin!
This is a sticky topic.
  • Important if you are using the Newtonsoft DLL in your plugin!
    The following changes need to be made in order for your plugin to function properly with the HS3 version 3.0.0.333 or later.
    If you reference the Newtonsoft JSON DLL in your plugin, make sure you install that dll in your own folder. Lets assume your plugin is named "AcmePlugin", your install.txt should install the Newtonsoft dll to:
    bin\AcmePlugin
    You should then include a exe.config file with the bin path set like so:
    <probing privatePath="bin/AcmePlugin;bin" />
    Note, many plugins are including the exe.config file and the bin path, but they are including "bin" before their own path, this is incorrect. Make sure "bin" is added after your private path.
    My BlueIris plugin fell victim to this issue for a number of users. I've added code to check for the DLL in the root and throw an error if it's there alerting users.
    However, I have one user that uses it in a script and is saying it needs to be in the HS3 root.
    https://forums.homeseer.com/showthread.php?t=190098
    I thought this could be solved using the ScriptingReferences parameter in the settings.ini file, but it would seem that's not working.
    Any thoughts?
    Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
      Did they put the newtonsoft dll in their own bin folder then put the path in the scriptingreferences like:
      bin/mypath/NewtonSoft.dll
      That looks like it should work. They cannot put it in the bin folder, that will break HS and other plugins.
      Any thoughts?
        Yes that is exactly what i troed, but that didnt work either. So made a folder in bin/scripting/newtonsoftblabla.dll
        And added this line in the scriptingrefrence, and restarted but did broke several scripts.
        Bart
        Regards Bart
        Win7 64Bit on Intel NUCI7 with SSD
        HSPRO 3.
        Devices; 1370 Events; 691
        Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
        Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
          Rich,
          Any solution for this, i cant remove the newtonsoft.json.dll to another location because it breaks my scripts.
          Regards Bart
          HSPRO 3.
            Do you have a sample script I can test with? Maybe the scripting references is not working properly.
            Originally posted by bartbakels View Post
            Rich,
              rich,
              i tried moving the newtonsoft.json.dll to bin and into bin\scripting and changing the scripting reference to;
              Newtonsoft.Json;bin\Newtonsoft.Json.dll
              Newtonsoft.Json;bin\scripting\Newtonsoft.Json.dll
              both created these errors;
              jul-24 9:29:28	 	Error 1	Running script C:\Program Files (x86)\HomeSeer HS3\scripts\Domoticz Interface.vb :Exception has been thrown by the target of an invocation.Could not load file or assembly 'Newtonsoft.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
              I will send you 1 of the the scripts by mail, because they include credentials which u need to test.
              Bart
              Regards Bart
              HSPRO 3.
                I tried it here with HS build 343 and it appears to work ok. My scripting references was set to:
                ScriptingReferences=Newtonsoft.json;bin\homeseer\Newtonsoft. Json.dll
                I don't know why it was not working for you, your references look ok.
                I assume this is on Windows?
                rich,
                Bart
                  nope,
                  still get the same error;
                  jul-24 18:12:34	 	Error 1	Running script C:\Program Files (x86)\HomeSeer HS3\scripts\Domoticz Interface.vb :Exception has been thrown by the target of an invocation.Could not load file or assembly 'Newtonsoft.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                  scripting reference entry is this in full;
                  ScriptingReferences=System.XML;System.XML.dll,System.Data;Sy stem.Data.Dll,System.Web;System.Web.dll,System.Web.DataVisua lization;System.Web.DataVisualization.dll,System.Drawing;Sys tem.Drawing.dll,Newtonsoft.json;bin\Scripting\Newtonsoft.Jso n.dll,DDay.iCal;DDay.iCal.dll
                  i am also on 343, and cant find any other newtonsoft files near the hs3 installation except in the bin subfolders...., maybe you are using the corrrect dll version by coincedence?
                  Bart
                  Regards Bart
                  HSPRO 3.
                    The problem is that the scripting system requires the referenced DLL to include the full path if its not in the HS folder. Odd, since if I just add a DLL it knows to search the HS folder.
                    So I automatically add the full path to any scripting reference to add.
                    For you to test, add the full path to the ScriptingReferences INI entry.
                    nope,
                    Bart
                      Rich,
                      What should be the correct syntax in that case to handle spaces
                      C:\program files\hs3\bin\scripting
                      Should i use "" or something else?
                      Bart
                      Regards Bart
                      HSPRO 3.
                        Looks like its double quotes:
                        https://msdn.microsoft.com/en-us/lib...v=vs.110).aspx
                        Rich,
                        Bart
                          ok i tried this now;
                          ScriptingReferences=Newtonsoft.json;"C:\Program Files (x86)\HomeSeer HS3\Bin\Scripting\Newtonsoft.Json.dll",System.XML;System.XML .dll,System.Data;System.Data.Dll,System.Web;System.Web.dll,S ystem.Web.DataVisualization;System.Web.DataVisualization.dll ,System.Drawing;System.Drawing.dll,DDay.iCal;DDay.iCal.dll
                          but then these in log;
                          jul-24 23:12:33	 	Error	Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\MeterstandenVerbruik.vb: Illegal characters in path.
                          jul-24 23:12:33	 	Error	Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\LogNetworkOutage.vb: Illegal characters in path.
                          jul-24 23:12:33	 	Error	Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Extern IP Monitor.vb: Illegal characters in path.
                          tried also to put it in de root and use this
                          c:\newtonsoft.json.dll
                          and this is also NOT working.
                          same error as in post above
                          Regards Bart
                          HSPRO 3.
                            any other suggestions?
                            bart
                            Regards Bart
                            HSPRO 3.
                              I can confirm this problem after moving the DLL file to the new location. All custom scripts using it fail on run....
