Registering my Azure app for OAuth2 with MyHS?
  • Registering my Azure app for OAuth2 with MyHS?
    Hi,
    I'm working on an Azure app that I'd like to be able to connect to MyHS, authenticated via OAuth2 (vs. passing user/password on the JSON URL). I'm assuming I have to register my app with HomeSeer MyHS somehow to do that and get some specific info to put in my app to handle the authentication process. I'm pretty sure this is what IFTTT does when you connect to HomeSeer via MyHS there. I'm not super familiar with OAuth2 so if I'm not describing it quite right, pls forgive me.
    Is there someone I need to contact for this or some sort of documentation or page of how to get this set up?
    thx
    XM
    Haven't seen an answer for this. Is there a better way to ask the HS support folks this question?
    XM
      I don't think it has ever been suggested that MyHS can be used by third party plugin creators in terms of the OAuth process anyway (you can connect to it by plain HTTPS passing the details in the parameters), I've certainly never seen it mentioned. Your best bet is likely to send an email to the support email address and see if they come back to you.
      My Plugins:
      Yeelight 3P | Nanoleaf 3P
        I think Imperihome uses myhs but spud had to get more info from HST on how to implement. You might send an email to support asking for info for your app.
        HS3Pro Running on a Raspberry Pi2 (Raspbian)
        64 Z-Wave Nodes, 162 Events, 293 Devices
          Thanks guys. This isn't a plug-in to HS3 in the traditional sense but something that runs in the Azure cloud that interacts externally through MyHS. I could pass in username/password but I'd rather use something like OAuth2 vs. passing in creds on the URL. I know it is possible as I am pretty sure that is how IFTTT links into MyHS when you connect them.
          What is the support email address?
          thx
          XM
            thx
            XM
            support@homeseer.com
            I'd be interested to see how this pans out.
              Thanks! I will loop back into this thread with the outcome.
              -XM
