SENSIBO - anyone ?
  • SENSIBO - anyone ?
    Hi Folks
    Has anyone toyed with the SENSIBO aircon device ? Developer has an API and a sample python script that seems to work ok. I think he's just enabled push notifications which is nicer than constantly polling his server via API.
    Must say for the first time I'm happy to use a device via IR....
    Pete
    HS 2.2.0.11
    SmarterControl has a plugin:
    http://www.smartercontrol.net/sensibo/
    Sadly, SmarterControl uses it's own "Updater style plugin" instead of the actual Updater for some strange reason, but I hear the plugin works.
      Thanks Moskus.....
      I'm going to give it to my Microsoft guy at work to pull apart and see whats in it :-) Again I'm curious as to how he is getting updates...
      Thanks for helping
      Pete
      HS 2.2.0.11
        Pete--
        Did you end up with an integration for sensibo? It looks like the sensibo plugin from smartercontrol is no longer supported.
        Greg
          Im also looking for a plugin for Sensibo , it seems like smartercontrol dont have it anymore
            i'm also desperate for a sensibo plugin since the smartercontrol one no longer works.
            I've got sensibo's across multiple client sites, so might even be willing to contribute to development costs if anyone here would be interested in writing one?
              Here you go
              https://www.hjemmeautomasjon.no/foru...meseer-plugin/
              Now, this links to a Norwegian forum, but the plugin is in English and you should probably be OK. I'll tell the author about this thread.
                Interested but it looks like the site is currently down.
                  Yes, we are aware, it's being looked into.
                    Anyone have any luck with either of the suggestions above? I just bought a Sensibo Sky, and would very much like to integrate into my HSPro
                    Fred
                      Yes, I downloaded the PI and it worked perfectly.
                        Awesome thanks, im going to try to get it working tonight..
                        thanks
                        Fred
                        Just curious, where did you download the plug in from? the zip in the forum is broken, and the link under that where someone tells him to upload here for easier finding, doesn't seem to have it listed...
                        also I did a translate in the page, you copy ALL of the files to the root of the HS folder? that doesn't seem right? LOL
                          From the site, I had to register first before downloading the zip file.
                            I get tested, if you are not logged in you will receive an error and once logged in it functions correctly and the zip file can be downloaded.
                              Just curious. Would an Harmony hub be able to do the same thing? For the control part.
