Getting Started?
  • Getting Started?
    All right, I want to get started writing a couple plugins for HS3, however, I'm finding the documentation is terrible, and the examples are not thorough.
    Does anyone have some places where you started? Some questions that I have so far that I haven't been able to find the answer to yet are:
    • How do I persist data for my plugin (I.e. If I call out to another web service and need to store credentials or an OAuth token)?
    • Are there examples of using the JQuery libraries with ActionBuilderUI, ActionFormatUI, ActionPostProcessUI, etc?
    • What capabilities are provided by HSPIBase.HS? I can't seem to find that documentation anywhere either.
    • How much money have folks actually made on plugins?
    Have you looked at the simplified, documented sample by Moskus?
    https://forums.homeseer.com/showthre...ghlight=plugin
    Fred
    HomeSeer Pro 3.0.0.548, HS3Touch, Zwave 3.0.1.252, Envisalink DSC 3.0.0.40, WeatherXML, Z-stick, HS phone, Way2Call
      My Plugins:
      Yeelight 3P | Nanoleaf 3P
        The Moskus samples referenced in the prior post are by far the most documented and easiest to start with. I wish someone would do the same for a C# example (Looking at you Frank! )
        I would pay for a good clean super documented Plugin Sample. Seriouslly if Moskus wants to make money he should clean up, re-document his sample and put it up in the store with a price. The same goes for sirmelli document the life out of a C# Sample plugin and I would gladly pay for it.
        Now with that aside. As for profit of plugins.
        1. I have plugins that I charge for yes.
        2. I have ZERO expectations of making a ton of money.
        I add a cost to the plugin because of support. Lets face it. Whether it's a free plugin or a paid plugin EVERYONE expects support for the plugin. Now the cost is decided by you but I try to keep mine reasonable based on the time of development and estimation of what it will take to support.
          Originally posted by mrhappy View Post
          1) Choice is yours, database, inside a device (PlugExtraData), INI file - really it is down to you, there is no set way of doing it. I mix between INI files but my preference now is to have a root device and store data in the PED of that device.
          Note that I started using PlugExtraData and it worked great for me and I loved not having to save to file. However I had users who where losing settings for one of my plugins so I moved to storing JSON files for my settings for that plugin.
          Note I never had an issue and maybe it had to due with the sheer amount of data I was storing which I didn't consider that much.
          Sent from my Pixel 2 XL using Tapatalk
          Frank
            As @jeubanks knows, I wrote a framework/wrapper that I use to significantly reduce my time to stand up and work with a plugin. I have considered sharing it, but I'm still deciding if it's even good enough to share. My MeiHarmonyHub plug-in uses it (as well as some I use just locally). It really works to strip away the stuff I felt was getting in the way. If I ever we're to write a sample plugin I would really on my framework/wrapper because it just simplifies a lot.
            I'm not trying to be a tease or anything I'm really not sure if the code is good enough to share. I'm sure ever Dev here has created a similar thing whether it be a frame work or vs template to get plugins stood up fast.
            Frank
              I'm just not good with C# so having a "Example Working Plugin" in C# would be a helpful tipping point to move away from VB
                I'm using https://forums.homeseer.com/forum/ho...erts-c-example - it's great and well commented
                  https://github.com/Moskus/hspi_CsharpSample
                  https://github.com/alexdresko/HSPI
